synthetic oil vs semi-synthetic - BMW M5 Forum and M6 Forums
Like Tree29Likes
Old 20th April 2008, 18:49   #1
derhammer
derhammer's Avatar
Garage: M5 3,6 sterling silber
Hi,
I am a bit concerned, I went to a independant bmw specialist and he did my oil change with semi-syntetic motul 15w50 oil. I always used castrol tws 10w60 in my engine.
He told me the tws I was using, was useless in my engine because it was designed for the latests bmw m power engines. He told me the motul oil was better suited for my car and that i was paying to much for the castrol tws. My concern is the change from synthetic to semi synthetic... Am I doing something wrong?
derhammer is offline   Reply With Quote
Old 20th April 2008, 19:11   #2
AfricaOffroad
AfricaOffroad's Avatar
Garage: 1991 E34 M5
A semi synthetic has a small percentage of Group 3 base oil in it - 10-20% IIRC.
Full synthetics comprise 100% Group 3 or Group 4 base oil. TWS is formulated with Group 4 (PAO).
TWS cannot even be compared to a Motul Semi Synthetic, the former is way way better in its lubrication properties. By way of example, normal group 1 base oil costs $1300per Ton. A group 3 costs about $2300per ton and a group 4 about $ 3500per ton. If oil companies could get the same lubrication properties with group 1s, believe me we would .
You dealer obviously has the Motul in stock - bulk or in 210L drums. He naturally wants to sell it to you.
1991 E34 //M5
2003 E55 AMG
2009 KTM 950 Super Enduro
2009 KTM 300 XCW
AfricaOffroad is offline   Reply With Quote
Old 20th April 2008, 19:19   #3
derhammer
derhammer's Avatar
Ok, thanks!.. but am I doing any wrong to the engine by running with that oil or should I switch to TWS again?
Old 20th April 2008, 19:30   #4
AfricaOffroad
Garage: 1991 E34 M5
Look if it were me, I'd replace it as soon as convenient to do so.
Providing you are not driving your car hard, running up to the red line, or tracking your car, its probably okay. That said, that not how one drives a //M car is it?
The Following User Says Thank You to AfricaOffroad For This Useful Post:
derhammer (20th April 2008)
Old 20th April 2008, 19:46   #5
davidoli
Fantastic response .......For a minute , I thought this was going to turn into another one of those inane oil threads .
It's suprising how many mechanics will base their advice on what suits their own purposes ........ thank god he didn't have a barrel of Planet oil in house !
91 Sebring 3.6 | E28 UK RHD M5 | E34 UK RHD 3.8 | E34 M5 Touring | E24 M635CSi UK RHD
www.classicmdautos.co.uk
davidoli is online now   Reply With Quote
Old 20th April 2008, 19:47   #6
Dan Kelly
Dan Kelly's Avatar
Garage: E34 M5 Sterling Silver
I have been advised by someone who really knows their stuff that they have seen accelerated wear in S38 engines with 10w60 oil. BMW recommend 10w40 or 15w50 oils for this engine, I would stick to that.
Dan Kelly is offline   Reply With Quote
Old 20th April 2008, 19:49   #7
derhammer
derhammer's Avatar
even if the car used synthetic oil in the past?
Old 20th April 2008, 19:53   #8
Dan Kelly
Dan Kelly's Avatar
I would still use fully synthetic oil for the reasons stated by AfricaOffroad but would avoid using 10w60 and stick to recommended ranges.
Old 20th April 2008, 19:58   #9
AfricaOffroad
Garage: 1991 E34 M5
Was that Raymond with the excessive cam lobe wear issue? If so, I suspect this relates more to the fact that occasional use allows the top end and oil channels to fully drain. On start up, top end could be a little oil starved for a few seconds.
If I lived in a cold climate, UK, Canada etc I'd definitely run a 0W?? (30 or 40), not a 15W. But it would be full synthetic (Group 4 based first choice, although 3 is also good stuff)
Old 20th April 2008, 20:08   #10
davidoli
IIRC it was one of the BMW Motorsport division guys in Germany that recommended the use of Castrol Edge / TWS 10W60 specifically for the S38 engine .
Do you mind me asking who suggested otherwise to you ?
We need to consider that oil technology has moved on vastly from 1995 when the last of these S38 engines were put into E34 M5s and the owner's manuals produced .
Your maintenance cost vs. your car year myztikal47 E39 M5 and E52 Z8 Discussion 25 3rd February 2010 20:54
Oil change andy777 E39 M5 and E52 Z8 Discussion 14 18th February 2008 03:28
Burning Oil david enock E39 M5 and E52 Z8 Discussion 25 22nd May 2005 16:15
Press Release no 2: The new V10 Power Unit in the BMW M6: A Masterpiece in Engine... Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 15th December 2004 00:15
Dealer says: New Serv. Bulletin Swtch to 10-60 w. capup E39 M5 and E52 Z8 Discussion 52 11th December 2002 03:05
