• Latest threads
    • Custom feed
      • Updates
        Old 17th March 2008, 20:37   #1 (permalink)
        A.W.O.L
        Track Days: any pro's to removing the highbeam?
        Are there any benefits to removing the highbeam light and allowing air to the intake for track days? Any significant power, or low end increase? What if it is a fast track and you see multiple 100+mph straights, would that speed hurt things?
        There are a few track days coming up and Im just curious if its something I should look into.
        1991 M5 - cams n' slam y0
        A.W.O.L is offline
        Old 17th March 2008, 21:01   #2 (permalink)
        Mmm-Five
        Don't bother!
        The n/s light is dead ahead of the airbox so any flow will be blocked anyway.
        The o/s light is slightly better positioned, but will possibly only slightly cool the washer bottle and your valve cover.
        Any power/increase will be negligible - might as well take a laxitive and **** between each session.
        "If you're not producing 'skidmarks' you're not trying hard enough"
        1990 e34 536i (junior)
        1994 e34 538i (deceased)
        http://www.mmm-five.net/
        Mmm-Five is offline
        Old 17th March 2008, 23:35   #3 (permalink)
        A.W.O.L
        Um, nothing blocks my airbox if the highbeam headlight is removed
        you can see the filter from the front of the car.
        Im just worried that there could be too much force when on those fast straights
        A.W.O.L is offline
        Old 18th March 2008, 00:57   #4 (permalink)
        Mmm-Five
        Sorry, I assumed you had a snorkel which picks up air from lower down in the engine bay
        Mmm-Five is offline
        Old 18th March 2008, 07:28   #5 (permalink)
        M5sedan
        M5sedan's Avatar
        race teams and frequent weekend racers have been doing it on E30's and E36's for years...........there must be a benefit when screaming down the front stretch and the engine begging for more air...........or under high load in high RPM's.........it couldn't hurt as far as I know..........you are just pressurizing the plenum with a charge of air less restricted that can either be utilized or not.........with the air mass meter in place, I don't think a lean condition could ever occur due to this........my 2 cents......hp/torque benefits = unknown
        so many mods......so little time.......
        '93 E34 M5 - Mauritius Blue/Dove Grey - 3.8 cam gears, Conforti chip, SLS-delete Ground Control/Koni suspension, Alpina Softline 18's, Rogue Engineering short shifter, Eisenmann Race exhaust
        '93 E34 M5 - Avus Blue/Dove Grey - 18" M-Parallels
        SOLD & Sorely missed: '02 E39 M5 - Carbon Black/Caramel - Rogue short shifter, Rogue Power Pullies, opened brake ducts, ellipsoid fogs, slide/tilt armrest
        M5sedan is offline
        Old 18th March 2008, 08:39   #6 (permalink)
        vadas1
        vadas1's Avatar
        I'm told that the most efficient place for air to get into the engine bay is via the headllight positions (some physicist demonstrated this on a NASCAR racer (the only racecar remotely approaching an e34 m5 in weight)) and for every 11 degrees F you can cool the air coming into the motor you get rewarded with at least 1 bhp.
        ralph (vadas1)
        * If it ain't broke fix it till it is *
        vadas1 is offline
        Old 18th March 2008, 13:47   #7 (permalink)
        nebpor
        Indeed they do - but not with the standard airbox!
        I'd say leave the entire intake system alone - it's a work of art.
        Common failing on Hondas (also great intakes) is to try and better Honda's design - it always loses power ot makes a nasty hole in the power ...
        I'd worry more about brake cooling for trackdays than engine power
        nebpor is offline
        Old 18th March 2008, 15:17   #8 (permalink)
        vadas1
        vadas1's Avatar
        Completely unrelated (sorry!), With the Honda airbox is it worth taking out the resonator box to improve airflow?
        ralph (vadas1)
        vadas1 is offline
        Old 18th March 2008, 15:40   #9 (permalink)
        nebpor
        I took mine out Ralph and ran a bit of central heating pipe down to the front airdam, but I'm up from about 190BHP on my ITR to about 230BHP .... it doesn't seem to make any difference on standard engines
        nebpor is offline
        The Following User Says Thank You to nebpor For This Useful Post:
        vadas1 (18th March 2008)
        Old 18th March 2008, 16:01   #10 (permalink)
        vadas1
        vadas1's Avatar
        Thank you for that
        ralph (vadas1)
        vadas1 is offline
