Who makes blue springs & adjustable bmw camber plates?? - BMW M5 Forum and M6 Forums
Old 8th February 2008, 02:39   #1
TurboWood
Garage: Black '93 M5 & Red '94 Supra
Hey guys,
I have a couple questions I'm hoping the M5 world can help me out with. I have a '93 M5 (US-3.6) which no longer has the SLS. The rear shocks are bilstein, but the springs are all blue. Can anyway tell me what aftermarket spring (or maybe stock) is blue?? Second, I've been talking with BMA (parts distributor) about camber plates and he found a couple interesting parts, but no information about them. If somebody familiar with BMW part numbers can figure out what these are I would appreciate it.
"Guide support camber correction (+30MIN.)" - 31 33 1 139 480
"Guide support camber correction (-30MIN/)" - 31 33 1 139 481
And for reference:
"Guide support" - 31 33 1 139 437
I believe that is the stock piece which can be replaced by the parts I listed above.
These parts appear to be front strut mounts. They have the three studs that actually mount to the chassis. Any ideas?
Thanks!
Daniel
TurboWood is offline   Reply With Quote
Old 8th February 2008, 04:16   #2
GoneAgain
GoneAgain's Avatar
Garage: 1988 Sebring Grey.....reborn
And for reference:
Thanks!
Daniel
I would say they are direct replacement adjustable top mounts.
[IMG]file:///C:/DOCUME%7E1/tli3823/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG][IMG]file:///C:/DOCUME%7E1/tli3823/LOCALS%7E1/Temp/moz-screenshot-1.jpg[/IMG]
http://bmwfans.info/original/E34/Lim/M5%203.6-S38/USA/L/M/1993/03/mg-31/ill-31_0128/
GoneAgain is offline   Reply With Quote
Old 8th February 2008, 05:43   #3
Nosilw
Garage: 95 540i Sport
Dinan?
I think Dinan makes their stuff in blue. They have a couple of different levels of suspension replacements for the E34 - from front dampers to whole suspension replacements and in between. Their level III includes adjustable camber plates and either Bilstein or Koni shocks - depending on the ride you are looking for.
Nosilw is offline   Reply With Quote
Old 8th February 2008, 06:19   #4
mblaster
mblaster's Avatar
Garage: 91 m5 black
since it looks like you have dinan springs pull off the shock tower cap(part 7) and see if you have the camber kit too.
91 E34M5 3.6 Dinan Stage 3, Konis, Dinan chip and cam gears, Kelleners strut bar,
Header back custom exhaust w/ Eisenmann Race 83mm, Staggered Polished T-Stars,
Passenger canyon puke bag.
mblaster is offline   Reply With Quote
Old 8th February 2008, 18:37   #5
legacy260
legacy260's Avatar
Garage: BMW E 34 LE M5 Rosso Red
Bilstein many moons ago sold the PSS9 adjustable kits with blue springs.
"Life's journey is not to arrive at the grave safely in a well-preserved body, but rather to skid in sideways, totally worn-out,shouting, 'Holy sh*t! What a ride!'"
E34 M5 LE 20/50 Rosso Red
legacy260 is offline   Reply With Quote
Old 19th February 2008, 08:36   #6
TurboWood
I took of the shock tower cap and everything looks stock. I even think the front struts are stock (except for blue springs).
I guess a previous owner was able to find Dinan springs and bought bilstein rear shocks when the SLS failed.
Does anyone have any experience with these BMW adjustable camber plates? Will they work with aftermarket struts?
Thanks,
Daniel
Old 19th February 2008, 21:15   #7
BoSJo
BoSJo's Avatar
Garage: E34 M20B25-->M50B25 -90 & E34 M5 S38B36 -91
I'd say that you should go for some after market adjustable camber plates.
http://www.realoem.com/bmw/showparts...=31&fg=10&hl=7
The only thing that i can see would give some real adjustment, is No. 13 on the above, as it might be out of center, and by turning it you would have 3 different settings.
Sorry, don't know of any after market camber plates
BoSJo is offline   Reply With Quote
Old 20th February 2008, 07:16   #8
WMWNWMN
WMWNWMN's Avatar
Garage: 1988 M5
BMW sold "crash mounts" for cars with tweaked frames. you could rotate the top mount in 3 different ways to get different effets.
i believe with crash mounts you get about 1/2 degree of negative camber in one setting.
I run ground control camber plates on my car. these have no rubber, so they aren't for sissies
WMWNWMN is offline   Reply With Quote
