Apparently my M5T (BL01842) '95 has no EDC! The front struts and the solenoid valves are there inlcuding the switch on the dash with the light working in both postions but.........NO wiring (can't even find them in the wheelhouse) to the solenoid valves whatsoever
In my humble opinion this could only mean two things! The dampers were gone some time ago and replaced with aftermarket shocks unsing the original struts or....the just removed the wiring for some reason
. This would mean if I understand correctly that ALL dampers have the default firm setting, even if the reardampers would work.
The general feel of the suspension especially with higher speeds is quit ok although it does feel very firm.
With very low speeds over bumps you can feel the front struts knocking... At the rear it feels as if there were blade springs mounted like in a truck.
I have a general urge to make the car as original as possible but that would probably mean replacing all the 4 EDC suspensions
.....or NOT??
