When filling the system initially, set both heater
controls to max heat, fan to at least Position I and have ignition on
position II (lights on) to enable heater valves to open fully.
If you are lucky (and it works
) you will hear the aux pump whinning
away..and it should go quieter as water makes it's way around the matrix.
If your aux pump works.....you can crack open the bleed screw for a while
to assist with purging before start up.
Best Regards,
Alan.
