Old 11th January 2008, 02:16   #1
Konfused Pete
Konfused Pete's Avatar
Garage: Black '90 e34 M5
Also need a part #
Hi All,
If you look at the front of the 3.6 motor next to the distributor/leads cover there is another small plastic cover which covers 3 little connectors for the ignition sensor, TDC sensor and air pump.
I am missing this little cover. If someone could check if there's a part number on it somewhere that'd be hugely appreciated.
I checked realoem and the best i could come up with is 12511312923 PROTECTION CAP listed under "Cable holders" in the engine electrical section. I only say this because it resembles pictures i have seen of it.
thanks
Pete
Konfused Pete is offline
Old 11th January 2008, 02:47   #2
91e34M5
91e34M5's Avatar
Garage: 91 e34 M5
Hey Pete,
You helped me...I help you. The part number on mine is 1312923. Same number as you list ...but with out the first four numbers. Attaches with one 10mm cap nut identical to the capnuts that are on the valve cover. Production date of my vehicle is March 90...of course its US spec. Hope this helps and good luck.
Murray
Dickson, Tennessee
91e34M5 is offline
Old 11th January 2008, 03:02   #3
Konfused Pete
I'd say that's a winner. single nut to mount matches the pic on realoem too.
cheers
Pete
Old 11th January 2008, 13:13   #4
Sebring NL
Sebring NL's Avatar
You need that nut too as its a special one.
Sebring NL is offline
Old 17th January 2008, 03:27   #5
91e34M5
91e34M5's Avatar
Garage: 91 e34 M5
Pete,
Got my light cover and attached cap today at the dealership....It worked.
Thanks for the help. You got your part yet?
91e34M5 is offline
Old 17th January 2008, 04:08   #6
Konfused Pete
I haven't yet. Been lazy. haha. I rang the dealer and they said It'd have to come from germany so i'd have to go pre-pay. might do it on the weekend.
Glad yours worked out !
Problems with 525i e60 bmw2004e60 E39 5 series Forum 6 22nd October 2006 08:54
Rear diff oil seal part number? illjah E34 M5 Discussion 6 13th August 2006 15:10
part number for infra red control unit remote key? M540i LE E34 M5 Discussion 1 29th June 2006 08:02
Part No. for rotors of 01' M5 E39 Eduardo E39 5 series Forum 0 22nd April 2006 03:11
Part number needed for Euro Lower Engine Cover WITH Brake Duct cosioboy E39 M5 and E52 Z8 Discussion 12 7th April 2006 19:27
Page generated in 0.10227 seconds with 11 queries
