Old 9th January 2008, 10:28   #1
Robert the chef
Garage: 1991 BMW M5
rotor
Can anyone tell me how to remove the front rotor?
Robert the chef is offline
Old 9th January 2008, 11:25   #2
davidoli
Hi Robert .....by rotor , I assume that you mean front brake disc ?
In which case , remove the front wheel and you should see a small allen bolt holding the front disc to the hub .......undo that allen bolt being careful not to sheer the bugger and the disc should slide straight off !
Good luck .....
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 9th January 2008, 15:48   #3
DrSakke
DrSakke's Avatar
Good luck .....
D
I would definately remove the caliper first.....
Take off the pads/compress the caliper so that it can be slided of, unbolt caliper(two bolts behind/on the backside of the caliper, 21mm??)
THEN undo allen bolt...bla..bla.....
Sakke
DrSakke is offline
Old 9th January 2008, 23:53   #4
davidoli
Well done Sakke ......I forgot all about rotors having pads and calipers to stop them rotating !
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 10th January 2008, 09:04   #5
Robert the chef
Garage: 1991 BMW M5
thanks guys
I was aware of the allen screw and caliper removal, but didn't know if there was more to it than that at first. Pulled it off!
Lug bolts stripped/ Rotor Assy too? speedmonkee E39 M5 and E52 Z8 Discussion 14 30th October 2006 16:06
Corvette ZO6 BBK (6&4 piston) on a E39 M5? KBK E39 M5 and E52 Z8 Discussion 14 3rd May 2006 15:53
Brembo thoughts: 8 pot calipers with a 355mm Rotor.... Clem E39 M5 and E52 Z8 Discussion 13 27th March 2006 18:25
Brakes and stopping distances... Val E60 M5 and E61 M5 Touring Discussion 28 20th June 2005 21:21
StopTechs and Track Use BarryC E39 M5 and E52 Z8 Discussion 36 10th May 2003 05:50
Page generated in 0.10408 seconds with 11 queries
