Old 2nd January 2008, 15:54   #1
DREAM 5
DREAM 5's Avatar
Garage: E34 M5 - S38 B36
Send a message via MSN to DREAM 5
Rough IDLE - Blimping while in neutral 600-990RPM
My car has had a rough idle for quiet some time, when u promote a jumpy idle eg. slight revving of car to 1300RPM while reversing, when back to neutral and idling car will bump around from 600-990RPM. Doesnt happen all the time though, once car is driven continously and driven a bit harder it steadys perfect.
Anything to be worried about?
Possible solutions?
S38B36 - 234.7RWHP
14.3 @ 99.8MPH
DREAM 5 is offline
Old 2nd January 2008, 16:23   #2
Evoman
Garage: Lancia Delta Integrale Evo 1
Hi,
I've only recently joined the club so don'tknowmy way round these cars yet - however, similar "hunting" on my Integrale has occured in the past and has been down to the idle control valve needing a clean with carb cleaner or equivalent, I presume there is a similar device on this beast - perhaps a good place to look initially?
Rich
Evoman is offline
Old 2nd January 2008, 17:21   #3
pfinucane
pfinucane's Avatar
Garage: E34 M5 3.6 Macao Blue
sounds like a maf problem to me
1991 3.6 Mauritius
pfinucane is offline
Old 2nd January 2008, 17:40   #4
ASBO
Garage: 996 GT3 and E32 735i
Or an air leak per chance?
Speed Yellow 996 GT3 Clubsport
DiamondSchwartz E32 735i
GE00286 Daytonaviolett E34 M5 3.8 6-speed (now departed)
Macau Blue E34 M5 3.6 (RIP)
ASBO is offline
Old 2nd January 2008, 18:01   #5
pfinucane
pfinucane's Avatar
yep-one of the many vacuum hoses !
1991 3.6 Mauritius
Old 2nd January 2008, 19:27   #6
farrell
farrell's Avatar
Sales Feedback: (4)
Yes
Vacuum hoses or Maf.
Do a search on both topics.
Also 8000 rpm limit etc etc..
I temper my advice on this based on the huge range of variables a a tuned eprom engine
with other modifications brings to the fault elimination procedure.
Whilst doing a search, I would recommend looking at the consequences of fitting an oiled filter
to this type of vehicle with its hot wire mass metering unit.
Cheers
Farrell
farrell is offline
Old 2nd January 2008, 21:22   #7
Lantz
Lantz's Avatar
Garage: BMW M5 E34 Granitsilber Metallic 3.8
Skip the K&N filter crap as they ruin Mafs. The original setut is very good
Also an 8000 rpm limit can have serious consequences for your engine such as resonance etc. I would recommend you return to the original limit as several cars that I have followed in Sweden have suffered serious engine failures due to this.
Lantz is offline
Old 3rd January 2008, 00:03   #8
DREAM 5
DREAM 5's Avatar
The hunting of idle is there even with standard chip in and when i got it from Japan, with 80 000Kms on it; it still did the same stock standard. Just not as bad.
I have got the chip in there only for the sake of the power gain in the higher revs but still gear shift @7000-7300RPM as I no that bottom end damage can be caused eventually.
Although we have chipped many E34 M5 3.6L and have used them on race and rally circuits for a good solid 2-3years and never had problems, however have had major problems with the 3.8L.
The Knn filter is in the stock airbox setup , just with a knn panle filter insert to replace the stock panel filter insert.
I have changed the MAF, TPS, Computer and found one air leak which was fixed in one vacumm line. However have not looked for more since.
I might have another look over the lines again and see if i can get anything.
S38B36 - 234.7RWHP
14.3 @ 99.8MPH
DREAM 5 is offline
Old 3rd January 2008, 01:45   #9
farrell
farrell's Avatar
Sales Feedback: (4)
Did this vehicle come to you as std with an idle & maybe other air / spark / fuel issues as std ?
Was it then chipped with existing condition ?
Were the MAF, TPS & DME diagnosed as faulty ?
You mention that you have been changing eproms on vehicles other than this.
Are you using Carsoft or Autologic diagnostics to interrogate the DME ?
This would rationalise diagnosis in conjunction measuring output
voltage etc at the relevant sensor plug.
K&N panel filter will kill & MAF just as quick as a cone but without the
thermodynamic issues of intake heat soak affecting the K&N cone filters.
Is the vehicle still running closed loop Lambda.
Whats th AFR on part throttle & WOT ?
What make of Eprom is fitted ?
Does it allow / inhibit the DME's ability to flash the self learning aspect of the driving
characteristics if you disconnect the battery or the DME from the power for longer than
30 mins ?
Farrell
farrell is offline
rough idle bobsalotto E39 M5 and E52 Z8 Discussion 1 31st May 2007 02:27
Rough idle batmonger E34 M5 Discussion 13 26th October 2005 13:38
Intermittent rough idle... lsdvm E39 M5 and E52 Z8 Discussion 4 12th April 2005 16:30
Page generated in 0.14836 seconds with 11 queries
