Old 1st January 2008, 06:03   #1
Mtechnik540i
Mtechnik540i's Avatar
Garage: Alpinweiss/Pacificblau E28 535is
Burning smell while idling...
Just replaced the valve cover gasket, and it seems that if the car sits for any prolonged period of time idling (which is rare), there seems to be a little bit of a burning smell, of which you can smell if the vents are open inside the car.
Popped the bonnet/hood and the smell seems to be mostly contained to the middle area close to the firewall.
I mentioned we replaced the valve cover gasket, but I've smelled new/fresh gaskets when they get hot, and this smells different. Along with this, you smell the front part of the valve cover and there's virtually no smell at all, it's pretty contained to the back of the motor/engine bay.
Any idea fellows?
TIA,
-Trevor Ely
"Other's do individual things better, but no car does so much so well" -Performance Car 1992
E28 535is
- Alpinweiss/Pacific
B5 1.8TQMS - Light Silver Met/Onyx Sport Cloth
E30 325is - Alpinweiss/Schwarz
E30 318is
- Brilliantrot/Natur
E30 325is
- Brilliantrot/Schwarz
E34 540ia M-Sport - Cosmoschwarz/Parchment
E34 M5 - Alpinweiss/Schwarz
Mtechnik540i is offline
Old 1st January 2008, 12:08   #2
farrell
farrell's Avatar
Sales Feedback: (4)
Occasionally, you do get a faulty valve cover gasket.
They then leak from the back corner of No6 cylinder.
Rare though.
Would suggest degreasng the area.
It may just be pooled oil that sploshed out on the manifold headers
when doing valve clearances etc.
Run the car as before & inspect from above & below.
See how far up the oil comes from.
Most oil leaks in this area are down to the "O" ring on the end of the
main oil drain return pipe from head to sump or cam chest hermetic
gasket breaking up which is common.
Cheers
Farrell
farrell is offline
Burning smell - maybe clutch? Have M will travel E60 M5 and E61 M5 Touring Discussion 3 21st November 2006 15:28
Burning smell when doing high speed runs? ///M5_Madman E39 M5 and E52 Z8 Discussion 24 10th October 2006 00:43
Troubleshooting burning smell after HID fog upgrade? black02m5 E39 M5 and E52 Z8 Discussion 2 11th March 2006 21:55
Occasional Funky Burning Metal Smell --no this isn't the name of a new rock band Anita E39 M5 and E52 Z8 Discussion 9 6th February 2006 03:36
Help!! My beast producing burning smell...Doc needed?? WarpSpeeD E39 M5 and E52 Z8 Discussion 13 5th November 2003 17:33
Page generated in 0.10617 seconds with 11 queries
