Old 31st December 2007, 02:04   #1
tomroche
Garage: e34 m5 daytona violet
Suspension
Hi,
Looking for some help/advice please, own a 3.8 and all dampers have been found to be leaking during the mot.
Looking to change to aftermarket suspension, have done loads of searches but I am now more confused than before
Will dinan suspension directly replace the original? i know edc needs to be removed but talk of 535 struts??
also what would you guys recommend going for? not that botherd about comfort as car is not used every day just weekend drives and odd track day.
One last thing can anyone recomend a dealer of suspension and any rough prices??
Car is booked on track day on the 12th so has to be done by then
Any help would be great please......
tomroche is offline
Old 31st December 2007, 03:28   #2
Sebring NL
Sebring NL's Avatar
IIRC Dinan suspension is Koni and they don;t fit into the rear without 535 top mounts and the front EDC struts won't take anything properly but EDC. So you'll need other struts aswell.
Whether or not you should delete EDC has been beaten to ***** here. Do a search for 500.000 threads.
Wout
Sebring NL is offline
Old 31st December 2007, 11:22   #3
nebpor
Garage: Avus Blue E34 3.8 M5
In particular, look for a thread by Kurt Ramsden (who was the previous owner of my M5) as he replaced EDC with AC Schnitzer suspension - once the bills added up it was as expensive as fitting new EDC
nebpor is offline
Old 31st December 2007, 14:32   #4
Mmm-Five
Did it actually fail the MOT on leaking dampers, or was it an advisory that they were seeping?
It will take weeks to get the parts, so it doesn't look likely that you'll be doing the event on the 12th.
2006 e86 Z4MC (überkart)
http://mmm-five.net/
Mmm-Five is offline
Old 31st December 2007, 15:44   #5
tomroche
no didnt fail but i drives rubbish on bumpy roads, especially at the front!
thats a shame if i cant get it done do you rekon it would be very bad on a track with the dampers as they are now??
tomroche is offline
Old 31st December 2007, 15:57   #6
Mmm-Five
If they've gone to the hardest setting, then they'll be fine for the track - as long as it's a smooth one
If they didn't fail the MOT and you've got no EDC warning, I'd guess they're just seeping - and maybe the harshness over bumps is due to something else
Mmm-Five is offline
Old 31st December 2007, 16:18   #7
tomroche
its not harsh over bumps, just bouncy!! have had leveling warning about the rear but only on occassions
tomroche is offline
Old 31st December 2007, 17:23   #8
stevie sam
stevie sam's Avatar
Garage: E39 M5 Carbon Black with Black/blue leather.
Hi tomroche........if the car feels pattery at the front over rough surfaces then your springs could do with changing ...
stevie sam is offline
Old 31st December 2007, 20:25   #9
GoneAgain
GoneAgain's Avatar
Garage: 1988 Sebring Grey.....waking up
http://cgi.ebay.de/BMW-e34-e32-M5-KW...QQcmdZViewItem
Look on the bright side, if I don't drive it for a year (2 years) the engine rebuild will pay for itself.(I'll make a profit!!).
GoneAgain is offline
Old 31st December 2007, 22:13   #10
Phlem5
Garage: 92 3.8, 5sp, Avus Blue(SOLD) & 95 LE 25/50
Hello tom, I recall that 'Cyrus' rated using koni dampers with h+r springs on his 3.6. IIRC, front top adjustable dampers were around £130 each and full set of h+r's are around £250. Cyrus / Sal, also sells these parts. As the guys have mentioned, you'd have to get a couple of standard front struts to put the front damper inserts in before you can get them on the car.
With the current price of edc units from the dealers at neigh on £800 a pop, I think the altenative route will be a solution seen on a few 3.8s.
Phil.
Phlem5 is offline
E39 M5 Rear Suspension Coil Over Install (long and detailed) jaj M5 E39 and E60 tips & tricks 1 25th June 2009 19:42
Question about the corvette and suspension in general? paulh GTBoard.com: General Sportscars 1 10th March 2005 18:51
Press Release 4: The suspension of the M5: Ensuring a high degree of agility Gustav E60 M5 and E61 M5 Touring Discussion 0 4th July 2004 22:03
Press Release 4: The suspension of the M5: Ensuring a high degree of agility Gustav Most Memorable Threads' 0 4th July 2004 22:03
Page generated in 0.13862 seconds with 11 queries
