Old 1st January 2008, 03:39   #11
Mmm-Five
Originally Posted by Phlem5 View Post
Hello tom, I recall that 'Cyrus' rated using koni dampers with h+r springs on his 3.6. IIRC, front top adjustable dampers were around £130 each and full set of h+r's are around £250. Cyrus / Sal, also sells these parts. As the guys have mentioned, you'd have to get a couple of standard front struts to put the front damper inserts in before you can get them on the car.
With the current price of edc units from the dealers at neigh on £800 a pop, I think the altenative route will be a solution seen on a few 3.8s.
My fronts are standard, but the rears have been replaced with Koni/H&R combo.
I like the ride, but I get the occasional rub on the rear nearside - which may be soon resolved with a small (1cm) spring mount or top mount addition.
2006 e86 Z4MC (überkart)
http://mmm-five.net/
Mmm-Five is offline
Old 1st January 2008, 06:09   #12
Mtechnik540i
Mtechnik540i's Avatar
Garage: Alpinweiss/Pacificblau E28 535is
Originally Posted by Sebring NL View Post
IIRC Dinan suspension is Koni and they don;t fit into the rear without 535 top mounts and the front EDC struts won't take anything properly but EDC. So you'll need other struts aswell.
Whether or not you should delete EDC has been beaten to ***** here. Do a search for 500.000 threads.
Wout
IIRC, Dinan actually offered you two options for struts, Koni or Bilstein.
-Trevor Ely
"Other's do individual things better, but no car does so much so well" -Performance Car 1992
E28 535is
- Alpinweiss/Pacific
B5 1.8TQMS - Light Silver Met/Onyx Sport Cloth
E30 325is - Alpinweiss/Schwarz
E30 318is
- Brilliantrot/Natur
E30 325is
- Brilliantrot/Schwarz
E34 540ia M-Sport - Cosmoschwarz/Parchment
E34 M5 - Alpinweiss/Schwarz
Mtechnik540i is offline
E39 M5 Rear Suspension Coil Over Install (long and detailed) jaj M5 E39 and E60 tips & tricks 1 25th June 2009 19:42
Question about the corvette and suspension in general? paulh GTBoard.com: General Sportscars 1 10th March 2005 18:51
Press Release 4: The suspension of the M5: Ensuring a high degree of agility Gustav E60 M5 and E61 M5 Touring Discussion 0 4th July 2004 22:03
Press Release 4: The suspension of the M5: Ensuring a high degree of agility Gustav Most Memorable Threads' 0 4th July 2004 22:03
Page generated in 0.09611 seconds with 11 queries
