I have been trying to retrofit Cruise COntrol for a while now and tonight i went about checking out my car and to try fit the parts i have aquired.
Anyway all i really managed was to remove the panels in the drivers footwell so that i could connect the cruise control stalk which i put in place only to discover the steering column shroud doesnt fit with the stalk in place so i then removed it again and put everything back together.
I then go to start the car and it doesn't start
It turns over and is definetly trying to go, there is a couple of splutters put just wont start. As if it isn't getting enough fuel or not sparking.
Is there anything in the footwell that could affect the car in this way, i did struggle to get a panel in and forced it a bit but i can't see any damage or disconnected wire.
Any ideas would be great thanks.
