Old 19th November 2007, 14:10   #1
ebbers
ebbers's Avatar
Garage: Avus Blue Monster
Battery trickle charger
Well the inevitable happened....
Battery died although to be fair looking at the previous bills I was going to have to buy a new one soon anyway.
Regardless I was wondering if anyone has used one of these solar powered trickle chargers?
Something like this:
http://www.bridgwater-electronics.co...le+Charger.php
Sounds good in theory but I was wondering how good it would be on a heavy duty battery or a big car like the M5 that can cause a big drain when parked up.
ebbers is offline
Old 19th November 2007, 14:41   #2
ebbers
ebbers's Avatar
Or is an Optimiser better?
http://www.thegreenreaper.co.uk/ShowDetails.asp?id=761
I was also reading that the M5 has it's own recharging point under the hood.
What sort of connector would I need for that?
I'm stuck at work at the moment and am "hoping" to pick something up on the way home.
ebbers is offline
Old 19th November 2007, 15:30   #3
shuggy47
shuggy47's Avatar
Garage: 93 E34 M5 3.8 Avus Blue
I have used a solar powered trickle charger for a few months now but it just seems to delay the inevitable i.e. battery dying.
As for the optimiser, i havn't used myself but my father swears by them for his motorbike throughout the winter when it gets little use.
shuggy47 is offline
Old 19th November 2007, 15:55   #4
ebbers
ebbers's Avatar
Cheers for the reply Shuggy47
Looking at the leads the trickle charger could be a set it and forget it item.
The optimiser works off a mains lead, not sure how I would be able to connect that up and leave it as the car is on the drive, not in a garage.
Hmmmmm.....
ebbers is offline
Old 19th November 2007, 16:47   #5
MY BUD
Garage: e34 3.8 M5, e34 B10 Biturbo, e39 530i.
I'd be interested to know what the best solution is, the M5 seems to go through batteries quite quickly and i normally use it only on weekends which does'nt help. A guy at work uses a solar charger on his Elise and is happy with the result, reading the previous reply however makes me doubt them. I've tried a standard battery charger with extended leads but the volt drop renders it useless. If it was my car on the drive i would put the optimiser in the boot and run an extension lead into the house or garage. With regards to the recharging point under the hood, i would have thought you are talking about the + nut you use for jump starting.
MIKE.
MY BUD is offline
Old 19th November 2007, 19:19   #6
dronfieldm
Garage: 1995 BMW M5 3.8 6 Speed - Avus Blue
Over the last 3 years I've only done about 1500 miles each year. The car is normally in a garage, and connected to a Halfords charger that also maintains, cutting in and out as required. I connected a lead direct to the battery and ran it into the boot with one of those "kettle lead connectors" on the end. (see attached pic). I put the opposite connector onto the charger lead and simply connect up, shutting the boot gently on the wire.......works fine.
I'd imagine you could connect the charger wires to the battery under the rear seat and run to the solar panel on the rear shelf perhaps ? if that's the way you want to go......
Obviously a 240 volt mains powered charger solution is a better long term prospect I'd have thought.
Mark
1995 3.8 6 speed - gone, but not forgotten.
1999 Land Rover Discovery Td5 ES
dronfieldm is offline
Old 20th November 2007, 00:09   #7
ebbers
ebbers's Avatar
Nothing like a bit of overkill.
Bought a 12v solar panel charger to see how it copes.
And a Ctek XS3600 charger and conditioner.
Now I've just got to find a decent supplier of a 100aH battery
ebbers is offline
Old 20th November 2007, 02:53   #8
legacy260
legacy260's Avatar
Garage: BMW E 34 LE M5 Rosso Red
CTEK 9000 for me....does a great job.
"Life's journey is not to arrive at the grave safely in a well-preserved body, but rather to skid in sideways, totally worn-out,shouting, 'Holy sh*t! What a ride!'"
E34 M5 LE 20/50 Rosso Red
legacy260 is offline
2001 M5 vs. 1968 Pro-touring Charger (pics & video) MrAngry E39 M5 and E52 Z8 Discussion 21 13th November 2007 20:42
Trouble codes and descriptions LeMansBlau E39 M5 and E52 Z8 Discussion 1 19th April 2007 16:43
Battery problems! Trickle charger recommendations? baldy_bonce E39 M5 and E52 Z8 Discussion 9 13th March 2006 02:52
Anyone use a trickle charger? JDOMROE E39 M5 and E52 Z8 Discussion 5 11th December 2003 15:22
Trickle Charger Andy G E34 M5 Discussion 8 11th March 2002 20:09
Page generated in 0.18962 seconds with 12 queries
