Old 18th November 2007, 17:51   #1
Usual Suspect
Usual Suspect's Avatar
Garage: 1992 e34 M5 Mauritius Blue
Valve Clearance procedure
Hi All,
Firstly, I am having a great time with my M5. It runs beautifully and have no issues to date. The engine sounds and runs smooth. The car has just passed the 35k kms mark. My question is at what mileage should I undertake the valve clearance procedure and at what intervals after that?
Thanks,
Terry in Toronto
92 e34 M5 J-Spec with E.A.T chip, Mauritius Blau
91 e31 850iA J-Spec, Conforti chips, Mauritius Blau (gone but not forgotten)
Two wrongs don't make a right. But three lefts do.
Usual Suspect is offline
Old 18th November 2007, 19:19   #2
Sebring NL
Sebring NL's Avatar
I wouldn't think the low mileage of your car now is any reason to assume the clearances are not due.
My personal experience is that the clearances don't get out of spec very soon, I recently checked mine after 10k km's they are still 100% in the same setting as when adjusted.
Simply leave the car at a shop overnight as it needs to be stonecold for this, and then have them checked/adjusted.
I check mine every 10k, and on cars I don't know I always check them if there is no record or the shop that has done it is not known to me.
Sebring NL is offline
Old 20th November 2007, 05:49   #3
Usual Suspect
Thanks. I will get them checked in the spring when I get my cam chain tensioner upgraded.
Terry in Toronto
Old 20th November 2007, 17:13   #4
Sebring NL
Sebring NL's Avatar
Upgrade the tensioner tomorrow please
Old 20th November 2007, 19:20   #5
Usual Suspect
I appreciate the nudge. It is only a matter of weeks before the snow flies she is put away for the winter (this is Canada after all). Until then she is only parked on level ground and no flogging. It will be job one this spring.
Terry in Toronto
FAQ on Carbon Build-Up Issue (First Attempt) LLcoolM5 E39 M5 and E52 Z8 Discussion 928 2nd November 2009 01:09
Trouble codes and descriptions LeMansBlau E39 M5 and E52 Z8 Discussion 1 19th April 2007 16:43
measuring valve clearance and re-shimming shuggy47 E34 M5 Discussion 1 22nd December 2005 19:18
3.8 M5 Engine Noise (Valve clearance ?) e34m5uk E34 M5 Discussion 14 5th May 2003 15:26
Valve clearance adjustment mikek E34 M5 Discussion 3 29th January 2002 22:28
Page generated in 0.12049 seconds with 11 queries
