Battery Life Expectancy - BMW M5 Forum and M6 Forums
Old 3rd October 2007, 14:00   #1
unesential
Garage: 1991 M5 black
Since joining I have read numerous threads on Battery not holding charge. I was just wondering if our beasts are also rough on batteries. I ususally expect 5 years of service from new however, I find myself in need after 3 years. Is the norm due to cycling from limited use or is it the nature of the beast. I don't let her sit on a maintainer as I tend to use about 2-3 days per week.
unesential is offline   Reply With Quote
Old 3rd October 2007, 16:08   #2
JED
JED's Avatar
Garage: E34 M5 Avus Blue
Sounds about right. Mines two years old, and showing signs already. I do keep it plugged into a battery conditioner now though to help it out.
If left on its own, it would discharge within three weeks.
JED is offline   Reply With Quote
Old 3rd October 2007, 16:33   #3
farrell
farrell's Avatar
Sales Feedback: (4)
3-5 yrs is normal dependant on usage.
My own experience echoes Jeds in that the car if left unused will flat the
battery almost completely in 2.5-3 wks.
That why I fitted a 105 Amp / 1400 mA battery to mine & a couple of other cars I have worked on.
You have a better charge balance ratio & the greater capacity gives you a
fighting chance of cranking first time after that 2 wk holiday.
Cheers
Farrell
farrell is offline   Reply With Quote
Old 3rd October 2007, 17:24   #4
legacy260
legacy260's Avatar
Garage: BMW E 34 LE M5 Rosso Red
I keep mine plugged into a trickle charger and it works beautifully. However before I did this within three weeks it would be flat. A replacement did little to improve the drain. Charge it or use it...
"Life's journey is not to arrive at the grave safely in a well-preserved body, but rather to skid in sideways, totally worn-out,shouting, 'Holy sh*t! What a ride!'"
E34 M5 LE 20/50 Rosso Red
legacy260 is offline   Reply With Quote
Old 3rd October 2007, 18:13   #5
unesential
the 2-3week drain down I understand and figure this what has caused the shortened life of the cells. Now if I only knew where I put the receipt for the last 72 month battery so I could get something off the knew one.
Old 3rd October 2007, 18:30   #6
Alan Archer
Alan Archer's Avatar
Garage: M5 3.8 Diamond Black
Have had one battery in 8 years,
probably around 3 years ago.
Went for a genuine BMW unit correctly rated too.
Dont use the car much during the week and sometimes its dormant
for a couple of weeks so it sits hooked up to an Oxford optimiser.
This ensures it never looses charge, essential with an alarm & 2 immobilisers!
What I would mention is I specifically avoided a fancy trickle charger
that cycles & does desulphation pulse charging and the like...
as I didnt fancy the cars electronics being subjected to voltage spikes
no matter how low the current...
Alan.
///M5 the only substitute for capacity is even greater capacity...
Alan Archer is offline   Reply With Quote
Old 3rd October 2007, 18:42   #7
farrell
farrell's Avatar
Sales Feedback: (4)
Good point m8.
I run a couple of optimsers...even so I use them, then disconnect & reconnect
once a week.
Cheers
Faz
Old 4th October 2007, 07:52   #8
Mmm-Five
Registered User
I've had 4 replacements in my 3.8.
  1. replaced original BMW battery when it wouldn't hold a charge.
  2. 2nd BMW melted and dropped its lifeblood in the battery compartment when the alternator overcharged it.
  3. 3rd battery (from RAC) did the same as 2 on the way home from being 'fixed' by the RAC
  4. Bosch battery with similar specs fitted.
Mmm-Five is offline   Reply With Quote
Old 4th October 2007, 10:28   #9
Teamsreth
Teamsreth's Avatar
Garage: E34 M5 LE in Rosso Red 22/50
I need to look into an optimiser, any ideas/recomendations?
What with the Alarm and Immobiliser, and the tracker, 2 weeks of inactivity will require a helping hand.
Phill C
Its not quite what I was looking for......
Its what I have always wanted!!!
Teamsreth is offline   Reply With Quote
Old 4th October 2007, 14:03   #10
unesential
So the question is does the optimiser extend the life to what the manufacturer gives in warranty or just buy a cheap battery and figure on relacing every couple of years?
New Battery for the beast. From Voltphreaks.com whatheheck E39 M5 and E52 Z8 Discussion 108 14th September 2007 04:19
Alarmingly short battery life stevieb E39 M5 and E52 Z8 Discussion 14 7th July 2007 09:09
Trouble codes and descriptions LeMansBlau E39 M5 and E52 Z8 Discussion 1 19th April 2007 15:43
Interstate MTP-93 Replacement Battery - check your installation greg E39 M5 and E52 Z8 Discussion 2 9th September 2006 00:10
Battery Life hollytree E39 M5 and E52 Z8 Discussion 1 17th July 2005 14:40
