Despite my better judgement , I made London Mike an offer that he simply couldn't refuse for his 1995 Alcantara interior and door cards .
I had always promised myself that I am not going to get hung up on the cosmetics of the Mauritius 3.6 as she will never be a minter , has done over 168,000 miles , has a peach of an engine and I would prefer to focus on the mechanics .
However , Mike's interior became available as my driver's seat began to display visible wear and the time seemed right .
I began by removing the rear seats and all four door cards :
quite straight forward , so no problems there .
I then fitted the alcantara rear seats and all 4 door cards , no problems .
The only things that remained were the front seats :
I purchased an E14 Female Torque socket from Halfords £2.50 approx
Which was handy because this is required to remove the torque bolts holding the seat rails to the chassis
and also the torque bolt holding the seat belt to the seat .......incidentally the seat base must be raised to it's greatest height to gain access to this bolt .
Everything was going swimmingly well and I got the alcantara passenger seat into place fully operational .
Finally , the driver's front seat with memory function was removed and the wiring plugs underneath differed from the passenger seat with only one white plug as pictured below :
The driver's seat had a yellow plug , a white plug and a black plug as well as a further black plug that connected to a female black plug separate from the first 3 plugs which were all connected to a black plastic box affair fitted to the underseat frame by two phillips screws .
This is when the problems began , as the alcantara non memory function driver's seat only had the one white plug similar to that of the passenger seat :
My dilema is , do I , start chopping about wiring at the risk at ending up with 2 driver's seats with non operational electrics or switch the alcantara trim onto the original driver's seat frame with half leather and the memory function thereby retaining the original wiring .
Or perhaps there is another option ?
London Mike may now understand why I was reluctant to start messing about with cosmetics now , although I am sure that this situation will be resolved in due course .
Any advice is welcome and appreciated ........
