help on E24 M6 wheel changeover - BMW M5 Forum and M6 Forums
Go Back   BMW M5 Forum and M6 Forums > BMW M5, M5 Touring, M6 and Z8 Forums > E31 850 CSi and E24 M635 CSi
E31 850 CSi and E24 M635 CSi M635 CSi (E24) 1983-89 and 850 CSi (E31) 1992-96. The Ultimate Grand Turismo by BMW M.
Old 5th May 2012, 01:57   #1
badabing
Garage: 993TT Midnight Blue/Flamenco Red
I just replaced the 415mm TRX wheels on my 1988 M6 with brand new 16X7.5 ET20 style 5's (E39) from the dealer with hubcentric rings.
However something does not look right. On the front wheels, there is a hair's worth of clearance between the face of the wheel and the brake caliper. Is this how it should be?
badabing is offline   Reply With Quote
Old 5th May 2012, 15:56   #2
First e28 M5
First e28 M5's Avatar
Garage: E24 M6's
Style 5's in 16 inch and 7.5 I have never ever seen that speck !
If you have the normal size 17X8 you want be that close to the caliper.
Hope this helps
Anri
__________________________________________________ _________________________
- It is super fun to build your own custom car the way you want it and like it.
- E24 M6 1988. Shwartz/Tan Original condition. Daily driver, keeper, Dinan suspension, Dinan adjustable sway bars, Evo S14 A100 cam gear, TMS chip, 360mm 6pot front, BBS 17x9,5 BBS E26 Magnesium Race wheels wrapped 255's.
- E24 M6 1988 Shwartz/Grey Collectible for shows 100% all original unrestored, keeper..
- E24 M6 1988 Shwarts/Lotus For Sale E24 M6 http://euroclassicmotors.com/galleries/bmwm6e24.html.
- E24 M6 1988 Royal Blue/Lotus white S85-B50 Restoration in proses.
- E24 M6 1988 Shwartz/Recaro S38-B36 3.6 goal is ~52/48 weight distribution at around 2800 pounds. My Track car for Vintage Racing !
- E30 M3 1990 Euro B38 3.8 goal is ~52/48 at ~2800 pounds.
- E53 X5 3.0 2003 Wife's car.
- E31 840Ci 1997 Black/Black, CSI exterior.
First e28 M5 is offline   Reply With Quote
Old 6th May 2012, 15:00   #3
badabing
This thread talks about 16" options
1988 M6 wheel/tire help - Bimmerforums - The Ultimate BMW Forum
Still not sure if this is ok or not.
Old 18th May 2012, 21:47   #4
sharkfan
Garage: Alpina B10 V8 Touring, Alpina B10 4.6 Touring, M635CSi, 635CSiA
I have fitted E39 17x8 and 17x9 Style 32's (with spigot rings of course) to my M635CSi. The fronts have ET20 as well and I have approximately 1mm clearance which hasn't troubled me for the last 3 or 4 thousand miles.
HTH
sharkfan is offline   Reply With Quote
Old 25th May 2012, 03:43   #5
Robert123
Garage: 1994 850CSi Schwartz 2
The original 415mm wheels that came on my '85 M635 had an et15. If you had the same ...... then a et20 on your new wheels would be 5mm closer to the brake caliper. However, I think the et 20 should be OK ..... as long as nothing is rubbing.
By r_e_l at 2012-05-24
Robert123 is offline   Reply With Quote
Old 20th November 2012, 11:59   #6
dhl93449
dhl93449's Avatar
Garage: 2002 M5 oxford green/caramel; 1985 M635 Naval Blue
The offset only defines where the wheel mounts to the hub. Has nothing to do with brake caliper/wheel structure clearance. That is up to the individual design of each wheel. Spacers can help because they move the whole wheel structure away from the brake caliper.
Personaly, I am using 17x8.5" Borbet alloys on my M635, with 235/40/17 rubber on all four corners. NO problems clearing my rotors, but the Borbet are designed with a short front lip, meaning the support structure is out away from the hub and brake calipers.
dhl93449 is offline   Reply With Quote
Old 20th November 2012, 12:04   #7
dhl93449
dhl93449's Avatar
Are those the original TRX 3 pc BBS wheels that were replaced due to cracking problems in the 80s?
Old 20th November 2012, 15:15   #8
Robert123
Yes, there was a cracking problem and a leaking problem ..... neither of which was experienced with the set that came with my '85 M635.
Old 15th January 2013, 04:26   #9
m41a1
Garage: C36 AMG Silver
IMO the era of the car looks better with 16".. But that's just my taste.
m41a1 is offline   Reply With Quote
Old 2nd February 2013, 10:41   #10
Ficelle
Garage: ///M6 E24 EURO 1985 Black
Yep !!
they are BBS RS007 .
I have them on my M6... it was a really expensive option in France.
but nether had trouble cracking or leaking...
and Michelin 240/45/ZR415 are really expensives also: more or less 450€ each !
M6 E24 EURO version 1985
shark attack !!...
Ficelle is offline   Reply With Quote
E24 M6 Frits E28 M5 Discussion 103 12th February 2011 08:08
E24 M6 in NH MMac Sightings / Spotted M5 around the world: was it you? 0 28th April 2009 18:29
Better value? 1985 e24 B9 or 1986 e24 B10 jrcalvin ALPINABoard.com | BMW Alpina Discussion 8 1st January 2006 19:50
Help wanted: E24 steering wheel swap Frits E31 850 CSi and E24 M635 CSi 0 29th December 2005 19:28
E24 and E24/1 JetBoy ALPINABoard.com | BMW Alpina Discussion 4 11th July 2002 18:11
