With the speed limiter in place, it's of course 250 kph (155 mph), without it the engine will rev to 6000 rpm (290 kph, 180 mph). That is a realistic speed to achieve under good conditions.
Then there's the possibility to lift the rev limiter to 6400 which will allow a maximum speed of almost 310 kph (193 mph). But as the power curve starts falling off beyond 5300 rpm (250 kph/155 mph) there's no way to pass 6000 rpm on a flat surface. You need a downhill section. But that speed is dangerous for the engine because oil supply isn't guaranteed any more (according to BMW). My personal record is at 305 kph (190 mph).
But the speedometer always runs ahead. At my 300+ run it already pointed into the void. It shows about 300 kph at 6000 rpm in 6th gear.
"How fast does your car go?"
"I don't know, the scale ends at 305 already..."
You can use a little
software (~60K) that I wrote to determine the real speed of your car.
But - I must say - that the experience of driving Mach 0.25
wasn't as exhilerating as I thought. I expected to wrestle with physics, but no. The car did that speed in a very determined straight line. Almost disappointingly unspectacular.
Almost
...Mike
