150k service recomendations - BMW M5 Forum and M6 Forums
Go Back   BMW M5 Forum and M6 Forums > BMW M5, M5 Touring, M6 and Z8 Forums > E28 M5 Discussion
E28 M5 Discussion 1984-1988
Old 28th December 2006, 18:32   #1
toys r' us
Garage: 1987 E28 M5
Hi all,
I've passed the 150K mile mark recently and was wondering if there are some items I should look out for regarding which should be replaced or serviced.
I get the car serviced about twice a year minor and major. The mechanic at the shop mentioned the timing guide replacement-is it really necessary to replace it?the argument seems to go both ways-I'm confused.
My third gear synchro seems to be wearing out too.
So, if the experts (you know who you are) can list the most important to the least important issues to look out for I would greatly appreciate it.
PS my car is mechanically sound, the only issue is loose steering and the third gear synchro which grinds on occasion.
TRU
toys r' us is offline   Reply With Quote
Old 29th December 2006, 02:20   #2
lkfosteraz
Garage: '88 US E-28 M5
I did my timing chain at 165k. The rubber coated rails weren't too bad off but the notorious $15 plastic guide was almost worn through it's mounting bosses. It's a PIA to do and expensive whether you do it yourself or pay a shop, but the odds are if you don't do it you will frag the motor eventually. I opted to do it and recommend that you do also. I never thought I had a loose chain until I started the engine for the first time with all the new bits. Amazingly more quiet, I can now hear the gear box rattle that I used to hear 15 years ago.
Have you changed your transmission oil? I use Mobil 1 ATF, but lots of people use Redline MTL. Either one may improve your shifting.
After replacing every moving part in my front end I found that the biggest improvement in steering came from tightening the steering column sliding spline coupling nut below the dash. You can reach this without removing the lower cover. Take a large crescent wrench (adjustable spanner) and place it on the nut next to the sliding splines and turn the steering wheel to tighten it. I kept tightening it until the adjustable steering column was tight to move in and out. Big improvement in straight-line tracking.
lkfosteraz is offline   Reply With Quote
Old 29th December 2006, 03:20   #3
toys r' us
Garage: 1987 E28 M5
thanks Ikfosteraz
The tranny fluid was changed in April along with the major service (Inspection II) Mercon ATF and some gear lube.I'll try the sterrin adjustment you mentioned. I guess I'll have to bite the bullet and do the time chain. While that is apart is there something else i could change along with it?
Old 29th December 2006, 05:16   #4
lkfosteraz
I replaced the oil pump while I had the oil pan down. Price from Steve Heygood was low enough that it made sense. Oil light goes off a lot faster now.
http://steveheygood.com
If you're going to have the TC done you might want to poke around to find a shop that knows the S38 engines. If you do the TC by the book you need to remove the head, but with a little poetic license with a grinding tool you can trim the top chain rail enough to do the change without pulling the head. Here's a step-by-step on how to trim the rail.
http://home.insightbb.com/~todd.kenyon/Chain.htm
Steve can provide the details here too.
Here's a good place to look for shop references.
http://www.mye28.com
Old 29th December 2006, 05:35   #5
toys r' us
Garage: 1987 E28 M5
thanks again
and continued health and happiness for the new year!
Is this usual behavior for a BMW service center or should I expect more? djmccoy77 E39 M5 and E52 Z8 Discussion 31 2nd November 2007 04:52
Service Engine Soon rsteele E60 M5 and E61 M5 Touring Discussion 0 24th February 2006 05:18
An Exceptional BMW Service Experience schnelleM5 E39 M5 and E52 Z8 Discussion 4 9th October 2004 21:41
what to do about horrible AT&T Wireless service in NC dmcgibbo Off Topic Forum 3 18th October 2002 06:08
New service policy MET E39 M5 and E52 Z8 Discussion 10 15th November 2001 02:54
