2nd May 2006, 22:20
#11
1988 M5 - Black
Make do
GSM5er:
Apparently I am the fortunate one who owns the only ///M5 E-28 in existence in South America; Bogota, Colombia and situations such as the one you`ve experienced are not uncommon to me. There are no mechanics who can repair this vehicle and the only dealership that might be able to service it is totally out of the question for many reasons. Luckily I have tinkered with unusual and classic cars most of my like: I drive and race Classic Minis, Porsches, and of course; BMWs.
I had the same problem as you did with the SLS... fortunately it was a broken hydraulic hose.. just as I was leaving on vacation with the whole family packed in.
Solution:
1. I had new hoses made all around (40 minutes) (to the shocks and in the pump itself).
2. Started the car and pressurized the pump.
3. Raised it all the way up.
4. got underneath the vehicle and disconnected the linkage between the pump and the stabilizar bar.
5. BY HAND, turned the lever on the pump until the car WAS LEVELED and exactly where I wanted it!!!! (by turning the lever a little... the car lowers, and a little more, it lowers a bit more, and so on...!
6. Totally removed the carburator linkage looking thing from the pump.
7. Removed the relay (blue) at the pump so it does not work any more.
The car has retained the same height since last year. It rides as usual. I have no problems any more!
and it did not cost me a thing except for the hoses which can be made rather cheaply and it is a better solution than buying Konis or replacing the damn pump or the entire system which will always be a big problem.
Good luck
