Originally Posted by Izzyzx
Mark,
Very good information. You seem like a expert in these matters... As you might have guessed I was not aware of a CPU difference. Is the Intel 8051 CPU only used on the E28 M5? Is this CPU and main board configuration unquie to BMW M5? Does any other manufacture us this CPU and MB?
A cpu from the 8051 family was used on all BMW's sold in NA from 1985 till the M50 motor was introduced, when they switched to an Intel 8096.
Some of the DME's using the 8051 are compatible, but you can not switch EPROMS between them as they are not hardware compatible. For example, the 153 DME was in an E30 and you can upgrade to the newer 173, but the hardware is quite different.
But in the case of the 079 DME from the S38, it is very similar to the 071 from the S14, and also the 059 from the M30. Yes you can even take the EPROM from one of those and swap into the other, but I wouldn't do it as even though the car will start and run, each has slightly different hardware and some functions won't be available. (you could do it temporarily if in a pinch). Those DME's are also very similar to the ones from the Porsche 944 DME.
I hope that answers your question.
Mark
