E28 M5 Discussion 1984-1988
Old 22nd February 2001, 17:49   #1
Ralph Seilius
Garage: none
E28 idle surge/hesitation
Help! My '88 is acting up, and it's really frustrating. Background: Built 3/87, mods are K&N filter, Dinan eprom; Remanufactured DME by Programa. After a plug/cap/rotor change and then sitting for 9 days in Norfolk VA, car developed a mid-range miss at 3000-4000 rpm. Next day, it would crank but not fire up. Towed to dealer, who cleaned fuel fouled plugs, check fuel pressure and vacuum, and got it started. Vacuum around 7 in; is that normal? Replaced ignition wires with 8mm set, ceaned air flow meter connection and plugs, replaced head-to airbox breather hose. Ran fine for about 20 minutes. Sat in parking lot, started up, idle surged from 800 to about 1500, steady. Pulled away in traffic, got a really bad miss/hesitation in 2nd around 2000 rpm. Cleared up, but shook the whole car. Local dealer can't connect up for diagnostics; car has 14 pin harness, they have 20 pin harness. Any ideas????
Ralph Seilius
Ralph Seilius is offline
Old 6th March 2001, 23:11   #2
MTY
Garage: .
Post
Hi,
I had the same problem. First time he just cleaned the injectors. He did nothing. Second time he changed the air flow meter, (whole piece). Now the car runs perfect. ( not a M5 e28, a Bmw 535i).
Hope this help.
Mikel.
MTY is offline
Old 7th March 2001, 17:00   #3
Ralph Seilius
Garage: none
Post
Hi, Mikel. I have since figured it out with help from the BMW CCA tech line and my mwchanic back home. The thermostat is sticking open. Coolant sensors detect low temps, and the computer thinks it's still cold enough to richen the mixture. Result-fouled plugs, rough running/hesitation, terrible fuel economy. I'm replacing the thermostat, coolant temp sensor and thermal time switch and the coolant. Thanks for responding.
Ralph
Originally posted by MTY:
Hi,
Hope this help.
Mikel.
Alpina/BMWM5.com meeting at Nurburgring Oldtimer Grand Prix 2003 kees ALPINABoard.com | BMW Alpina Discussion 15 20th September 2003 02:46
My visit to the Old Timer Grand Prix on the 10th of August raymondw Regional Forums and Events and group meetings for M5, M6 and Alpina owners 2 26th August 2003 01:05
My visit to the Old Timer Grand Prix on the 10th of August raymondw Most Memorable Threads' 2 26th August 2003 01:05
AMS Article E28 B7/2 turbo vs E28 M5 available for download raymondw ALPINABoard.com | BMW Alpina Discussion 8 16th May 2003 19:26
Page generated in 0.10143 seconds with 11 queries
