Hartge M5 - Page 2 - BMW M5 Forum and M6 Forums
Go Back   BMW M5 Forum and M6 Forums > BMW M5, M5 Touring, M6 and Z8 Forums > E28 M5 Discussion
E28 M5 Discussion 1984-1988
Old 9th November 2005, 19:02   #11
Birds Hartge
Garage: Hartge 330 Supercharged & E36 M3 Lightweight
Re: Hartge M5
Originally Posted by Cyrus
welcome abaord Kevin,
its great to see the owner(s) of one of the best tuning companies on here answering the questions.
I got one question, could the S38B36 engine benefit from those modifications and if so which ones? Have you eve modified the S38 from the E34?
Hartge used similar modifications in the H36, the S38 B36 engined M3. I owned one for quite a while, and Hartge told me that the particular car I had developed nearly 360hp when they had finished with it! Certainly felt like it...
With all of these types of engine, there was no "kit of parts" and no generally available solution. Each one was done individually, and the results were entirely subject to workmanship at the Beckingen factory. I'm sure that they could and would do the same again, and I'm sure we could replicate their work here in Uxbridge. It involves camshafts, installation of the same, and a considerable amount of work on the existing head, valves and inlet systems. Engine management would have to be remapped as a consequence. My best guess at a price would be 5k, which is a lot of dough, but there is a considerable amount of machine work and fettling to be done to better BMW M's handiwork, as you would expect!
Birds Hartge is offline   Reply With Quote
Old 9th November 2005, 19:48   #12
Cyrus
Garage: BMW E34 M5 3.8 Avus Blue
Re: Hartge M5
When you do work to a car do you dyno it after wards to show the gains?
I know alot of E30 owners are interested in the H26 conversion but want to see that proof it makes 190 bhp.
Cyrus is offline   Reply With Quote
Old 9th November 2005, 19:50   #13
Ashok Arora
Ashok Arora's Avatar
Re: Hartge M5
Welcome aboard Kevin
Why not come along to our meet on December 4th - a lot of your past, present & future customers will be there (all happy of course):
http://www.m5board.com/vbulletin/sho...603#post629603
Ashok
next up.. 2013 F30 Alpina B3
http://www.m5board.com/vbulletin/e60...kend-hell.html
Ashok Arora is offline   Reply With Quote
Old 15th November 2005, 19:56   #14
hertfordshire1
hertfordshire1's Avatar
Garage: BMW M5 e34
Re: Hartge M5
Hmmmm.
hertfordshire1 is offline   Reply With Quote
Old 17th November 2005, 21:54   #15
Birds Hartge
Re: Hartge M5
You should really be happy that Hartge made that claim under strict German legislation. Given that there are no exhaust manifolds available any more, we do a bit more work to the cylinder head to compensate. I would have no problem guaranteeing the additional 20hp. However, the car would need to be tested both before and after the conversion, as it is unlikely that cars of this vintage actually produce the original BMW spec. 170hp. I guess we must have done around 50 such conversions, without complaint (so far so good!)
Old 7th December 2005, 12:12   #16
Jahangeer
Jahangeer's Avatar
Garage: .................
Re: Hartge M5
Hi Kevin
Along with the other members I also welcome you aboard, and it is great to have a knowledgeable person such as yourself writing here. I have a question...one that has been asked many times..
What could you safely/reliably extract from the 3,8 block on the E34 M5, as a daily driver?
I have the Schrick cams and a UNICHIP and 100 cell catalysts. I suppose extensive headwork?
Regards
J
Jahangeer is offline   Reply With Quote
Old 7th December 2005, 16:13   #17
Birds Hartge
Re: Hartge M5
Originally Posted by Jahangeer
Hi Kevin
Regret to admit I have no answer for that one. The 3.8l was very late in BMWs development path, and only presented limited appeal for tuners, therefore nothing serious made it into the marketplace.
As with most M engines, someone has already done the fettling work to quite a high standard, so gains are relatively poor for quite a lot of effort (=cash). Best way forward would be to convert the engine management to alpha-n, using MoTec. Expensive, but you are guaranteed to get better performance in absolutely any engine configuration you may arrive at in the future. If they or their dealers have done a configuration like this before, then you will be able to tap into existing knowledge. Would be nasty if you had to fund your own development costs though.
Otherwise, a really careful set-up and remap of the existing engine management would be the only other route to get the best out of what you have. I would guess that you would only see maybe another 20hp from really slick headwork.
Old 7th December 2005, 16:29   #18
Jahangeer
Jahangeer's Avatar
Re: Hartge M5
Thanks Kevin - it is as I thought - the law of diminishing returns heavily applies. Have considered MOTEC alpha-n systems - but I want a reliable daily driver.
Sorry guys - getting of-topic.....will end now.
Thanks again Kevin.
M5 E39 Body Style S62 engine FACTS...Long V-10 4 Me E39 M5 and E52 Z8 Discussion 63 5th June 2012 22:00
2 weeks old: My impressions of the SL 55 vs. M5 (very long) Rezf E39 M5 and E52 Z8 Discussion 34 30th September 2006 01:30
Official press release: Engine / Drive System enots E60 M5 and E61 M5 Touring Discussion 9 24th June 2004 00:50
BMW M5 culture over the net Rodrigo Feher E39 M5 and E52 Z8 Discussion 8 22nd December 2003 01:04
