E28 M5 Discussion 1984-1988
Old 13th November 2002, 22:08   #1
jefrem
jefrem's Avatar
Garage: Black 1988 M5
engaging 1st gear
hello all,
i recently (3 days ago) acquired an e28 M5. while many little things need attending-to, in general its in fine stock shape. anyways, one of the little things is an occasional difficulty engaging 1st gear. some preliminary research indicates that what i was about to do (change the tranny fluid with Red Line MTL) is perhaps not advisable on the Getrag 280, as it perhaps prefers mineral-based ATF.
opinions?
it doesn't seem like a pilot bearing issue, as 1st is the only gear affected. my guess is some less than gentle downshifting by the previous owner.
thanks,
-jefrem
jefrem is offline
Old 21st November 2002, 02:24   #2
Mfiver
Mfiver's Avatar
Garage: E28 M5 - Cirrus Blue - 1987
Re: engaging 1st gear
This sounds more like an impending clutch slave cylinder or master cylinder fault. My own M5 exhibits this - gradually getting worse - and the M535i I had before did the same. In the case of the M535, a new slave cylinder solved the problem.
Try rapidly pumping the clutch pedal a few times and if it then slips into gear easily, that's where you need to start looking!
I would suggest that if you stick with the stock transmission oil, you shouldn't have any problems.
Mfiver is offline
Old 6th December 2002, 18:47   #3
jefrem
jefrem's Avatar
definitely not a master/slave cylinder problem. the more i drive with it, the more i'm convinced its either a pilot bearing or a pressure plate problem.
we'll know soon enough, as i'll be replacing all this when i do the ltwt flywheel.
thanks for your reply.
regards,
-jefrem
jefrem is offline
My transmission kicked me out of 1st gear... beanboy E39 M5 and E52 Z8 Discussion 22 5th November 2005 18:45
Rev limiter in 1st gear VanM E39 M5 and E52 Z8 Discussion 5 26th July 2002 19:33
SL 55 vs Z8 at the Nurburgring! mmunson E39 M5 and E52 Z8 Discussion 64 21st April 2002 02:42
Rev limiter on 1st gear madmmt E39 M5 and E52 Z8 Discussion 4 13th November 2001 09:08
KirklandM5, when are you doing the Dinan LSD tests? kenneth E39 M5 and E52 Z8 Discussion 45 28th July 2001 20:57
Page generated in 0.10988 seconds with 11 queries
