Upcomming issues on #231 (ABS system, front wheel shimmy) - Page 6 - BMW M5 Forum and M6 Forums
Go Back   BMW M5 Forum and M6 Forums > BMW M5, M5 Touring, M6 and Z8 Forums > E28 M5 Discussion
E28 M5 Discussion 1984-1988
Like Tree19Likes
Old 26th March 2012, 20:28   #51
raymondw
raymondw's Avatar
Garage: 1990 BMW E34 ///M5 (181), 1985 BMW E28 ///M5 (203), 1988 BMW E32 735i (198), 2003 BMW E39 530i touring (354)
I have decided to replace the front shock absorbers nonetheless because the right example devellops a 'cluncking' sound on rougher roads. OEM Bilsteins are still available from BMW so I bit the bullet and bought some to replace the front-pair.
As a bonus, a few pictures from the 2010 trip to the Ardennes with the Dutch E21 owners group.
Raymond
==> MY90 E34 M5 3.6 <==
==> MY85 E28 M5 M88/3 <==
The E34 M5 Alps tour. Sixth edition: 14-17 September 2007
raymondw is offline   Reply With Quote
The Following User Says Thank You to raymondw For This Useful Post:
BMWWGN (26th March 2012)
Old 26th March 2012, 23:26   #52
BMWWGN
Garage: 1994 E31 850CSi Sterlingsilber
Thanks for posting Raymond,
It's good to know the OEM shocks are still available for the pre-Oct '86 M5's, although I'm guessing that the price was exorbitant.
Also good to see your car outdoors again, and no doubt being driven as its maker intended!
Looks like some under-body cleaning may have been required after that trip.
BMWWGN is offline   Reply With Quote
Old 27th March 2012, 00:08   #53
raymondw
raymondw's Avatar
They cost an arm and a leg; but still not as much as a Boge front shock absorber of a HD91 E34 M5. I paid around 300 Euro/each (incl VAT)
BMWWGN (27th March 2012)
Old 27th March 2012, 07:47   #54
Stoffie
Garage: BMW M635CSi Schwarz
My attempts to get them straight from Bilstein proved to be a tiresome and exhausting story, so I ended up buying them from BMW as well. About a year ago I paid more than 400 a piece, so I guess you got a pretty good price on them!
Stoffie is online now   Reply With Quote
Old 23rd September 2012, 23:10   #55
raymondw
raymondw's Avatar
After waiting for almost two years, the new output flanges came in about a week ago. Their price has risen to 107 Euro plus exchange ex VAT, but this still beats the price for remanufacturing on own initiative and directive.
When I examined them more closely, I noticed that these are made from aluminum rather than cast from steel as the original ones. I suspect that the original tooling is no longer available and that BMW decided to have them machined and not casted. This can be done straight from a CAM-file by a routing-machine without additional tooling, but the process is more expensive.
The advantage of alloy is that they won’t corrode, but whether these will be able to withstand the M88/3’s power remains to be seen. This especially applies to Alpina’s B7 turbo that yields more than 500Nm of torque on the crankshaft.
I also have some new OEM front springs that will be fitted in the winter of 2012/2013 together with the new shock-absorbers.
Old 4th October 2012, 06:58   #56
First e28 M5
First e28 M5's Avatar
Garage: E24 M6's
Touch up...Typo :-)
Ray,
Every time I am going through #231 E28 M5 rebuild and see all these sweet brand new parts you are buying. I have noticed there is not even one part that is good quality aftermarket to improve the over the factory design...Small and just an example...I had to go through many bushing being Mahle made for E24/E28 cars but smaller to fit the E24/E28 place without to stretch the bracket...exact what you have there after not to many miles the annoying shimming is back as again and again...In order to replace the upgraded bushing from Mahle you Must have to have the tool to remove the bushing while the Arm is connected to the suspension. If you try to remove the arm and do it outside the car you are going to damage 100% the balljoint rubber because no chance and way to take it out without damaging it. The simply the grease is going out and the joint is drying...Bear in mind I have 160.000 kilometer behind my back on the same exact suspension ! just badged differently. I am positive sure that you don't have the experience to see what part will last long etc..
Not to mention I did drove my daily driver complete Dinan suspension E24M6 at the local Canyons and after ~40miles of fun only sharp turns they were destroyed again...The shimming is bag again.
Yes the installation was done correct every single time by having the car on a drive in jack so the body will sit on its shoes and then tight the Green/bushing..
So many years pass since I dont have that problem any more ! Thanks to the Spherical Bearing/Bushing I have on my car. As I can see you are using a factory 225 50 16 tire profile that means that the Side Wall is very soft, tall and smooths out all the road imperfections..you know what I mean..You are not driving on a 19 inch with 30 profile tires. Using a Spherical bearings/bushings will make the steering super tight and the feedback that our old school BMW have and grabbed the World with that feeling will only increase !
Exterior Touch up.
Ray I am not trying to pick on you what so ever, its all my opinion weather its worth a something or not..
I have noticed your "M5" badge is not in the proper Factory place, looking at this picture taken at the reaver.
The reason I am pointing is because after I have complete restored many Mercedes and BMW M6's few E28 M5's they have that badge and when do complete restoration then you lose the proper badge place and then it does look funky, at least to me.
I am turning even more picky every time I do restore the next car...That is only making the new owner only one way, being happy...
I took the measurements on the E28 'M5' Badge but dont know were it is since its has been years since I restore the last E28 M5. If I were you I would take the badge off and get a Factory picture and chop that on photoshop take some measurements.
Get a spray water mixed with a dishwasher soap spray the area and apply it light then measure it and before you press hard step away 10 meters or so and see it visually to see the outcome look.
By the way have you ever thought to install the M-Tech factory rear spoiler ? or stock look is preferred.
Heat is I am attaching you few pics..
Regards
Anri
__________________________________________________ _________________________
- It is super fun to build your own custom car the way you want it and like it.
- E24 M6 1988. Shwartz/Tan Original condition. Daily driver, keeper, Dinan suspension, Dinan adjustable sway bars, Evo S14 A100 cam gear, TMS chip, 360mm 6pot front, BBS 17x9,5 BBS E26 Magnesium Race wheels wrapped 255's.
- E24 M6 1988 Shwartz/Grey Collectible for shows 100% all original unrestored, keeper..
- E24 M6 1988 Shwarts/Lotus For Sale E24 M6 http://euroclassicmotors.com/galleries/bmwm6e24.html.
- E24 M6 1988 Royal Blue/Lotus white S85-B50 Restoration in proses.
- E24 M6 1988 Shwartz/Recaro S38-B36 3.6 goal is ~52/48 weight distribution at around 2800 pounds. My Track car for Vintage Racing !
- E30 M3 1990 Euro B38 3.8 goal is ~52/48 at ~2800 pounds.
- E53 X5 3.0 2003 Wife's car.
- E31 840Ci 1997 Black/Black, CSI exterior.
First e28 M5 is offline   Reply With Quote
Old 4th October 2012, 07:05   #57
First e28 M5
Garage: E24 M6's
ABS wheel bearing Ring teeth
Missed to see the picture you have changed it with brand new part. Never mind
Old 4th October 2012, 07:14   #58
BMWWGN
Originally Posted by First e28 M5 View Post
I have noticed your "M5" badge is not in the proper Factory place.......
You can check it against the following dimensions, which are deemed to be correct for the E28 M5:
From the right edge of the boot lid to the right edge of the "5" = 54mm
Space between the right edge of the "///M" to the left edge of the "5" = 8mm
From the bottom edge of the boot lid to the bottom of the "///M" and the "5" = 25mm
Cheers
The Following User Says Thank You to BMWWGN For This Useful Post:
raymondw (7th October 2012)
Old 4th October 2012, 07:45   #59
First e28 M5
Garage: E24 M6's
Cheers
Are these measurement taken from the factory spec ? You have not mentioned that ?
In my opinion Ray's '///M5' badge sits little too high...but that could be just me...Regardless that the car does not have a factory M-Tech spoiler.
Anri
Old 7th October 2012, 15:13   #60
raymondw
raymondw's Avatar
Anri
Gents,
I am not a detailling-enthusiast, so I cannot really bother about a few millimeters. What I do know is that #231 still has its original paint and it did not come with the badge-delete option. A previous owner may have removed it and later got regrets; maybe ? but that is a fact-finding that I do not care about.
- Does the badge improve the handling ?
- Does the badge make the car faster ?
- Does the badge improve fuel-efficiency ?
There are dozens of other issues to concern about with these cars and I already do not have that much time driving my cars. Less than 700km this year with a prospect of not exceeding the 1500km. Having said that, we will have a season closure meeting the the south of Limburg on Sunday 21-October and I already look forward to that.
As a matter of coincidence, I took #231 out for a goof warming-up drive last Sunday evening. Took the opposite direction of my usual-route; followed the 120kmh restricted A1 towards the German border near de Lutte; from there the A30 towards Hannover untill highway intersection with the southbound A31 near Schuttdorf. I drove almost 160km in just 90 minutes including a fuel stop in Gronau for Shell's finest. Todays fuel-prices are already dismal, but why bother.....
Maybe I will buy myself a GoPro Hero2 for the fun of it.
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
Mick leno
Replica wheel shimmy Brother Methias E39 M5 and E52 Z8 Discussion 2 15th July 2010 20:47
Is my M5 a 4x4 (front wheel gap issues) doug_999 E60 M5 and E61 M5 Touring Discussion 18 21st November 2008 16:43
HELP...I'm having a nightmare....! [Troubleshooting ABS, DSC & satnav issues] BISPAL E39 M5 and E52 Z8 Discussion 6 27th September 2006 18:13
steering wheel shimmy slowcar E39 M5 and E52 Z8 Discussion 3 5th May 2005 00:07
Front end shimmy brutus E39 M5 and E52 Z8 Discussion 6 13th February 2002 06:37
