Just joined :) A few pics of Babe. - Page 36 - BMW M5 Forum and M6 Forums
Go Back   BMW M5 Forum and M6 Forums > BMW M5, M5 Touring, M6 and Z8 Forums > E28 M5 Discussion
E28 M5 Discussion 1984-1988
Like Tree56Likes
LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 26th June 2012, 09:36   #351
Fordkoppie
Fordkoppie's Avatar
Garage: E34 3.6 M5 Glacier Blue, E34 540i/6 Individual, RS 5000 Ford Sapphire, 323i e30 2dr, 1965 MK1 Cortina GT
Originally Posted by e28s38b36 View Post
Still been getting a bit of over cooling due to the size of the radiator. Last weekend I fashioned up a shield that blocks 80% of the front of it. It works! My temp needle now sits at 11 o'clock at 100mph....urrrr 70mph
A new thermostat would have cured that as well.
Fordkoppie is offline   Reply With Quote
Old 26th June 2012, 12:15   #352
e28s38b36
e28s38b36's Avatar
Garage: 1986 e28 with s38b36 engine & gearbox, 380mm front, 360mm rear AP Racing brakes etc etc etc.
The thermostate is less than 7 months old. The old one did the same thing.
e28s38b36 is offline   Reply With Quote
Old 26th June 2012, 12:24   #353
Fordkoppie
Fordkoppie's Avatar
Weird. It is supposed to maintain temp irrespective of how cold or large the reservoir/radiator water is.
Old 26th June 2012, 13:58   #354
e28s38b36
e28s38b36's Avatar
Correct.....but theory & reality are to different things!
The surface area of five cores means that when the thermostat does open the cooling effect of that massive surface area is magnified well beyond a standard e34 M5 radiator. Remember that the water pump does not stop running or slow down! I could try an undersized pulley for it but I'm leaning towards having another radiator made that has the same surface area of the standard radiator if push comes to shove.
Mine holds 8L more coolant than a standard radiator! That's a lot!!
The thing is though by covering the front of the rad I'm protecting it from road debris & the extra capacity means that I can drive the car harder for longer which is no bad thing. I've adjusted the electric fan to come on later too which has also helped.
I have also been unscrewing the expansion tank top after the car has been on a run to release any trapped air.
The Following User Says Thank You to e28s38b36 For This Useful Post:
Fordkoppie (26th June 2012)
Old 17th July 2012, 12:06   #355
e28s38b36
e28s38b36's Avatar
Finally found it!
Finally found my cooling problem
It turns out it's the radiator! The welding around aux coolant temp bung (That I didn't ask for) is porous It only shows it crap build quality once the system is full pressurized.
The pictures shows the tell tail signs. I have put some type of putty around it for the moment which has worked. The idea is to see it the rad is leaking elsewhere also. When I calm down I will give the radiator chap a call. I want a completely new radiator from him.
What a waist of £750!
Just joined :) A few pics of Babe.-100_3378.jpg
Old 26th July 2012, 12:02   #356
e28s38b36
e28s38b36's Avatar
Radiator removed & repaired. Both drain plugs removed & holes welded up. Metal blanking plate fitted. Old fan fixings removed & radiator repainted.
Just joined :) A few pics of Babe.-100_3383.jpg
Just joined :) A few pics of Babe.-100_3391.jpg
Just joined :) A few pics of Babe.-100_3392.jpg
Just joined :) A few pics of Babe.-100_3394.jpg
Just joined :) A few pics of Babe.-100_3395.jpg
Just joined :) A few pics of Babe.-100_3396.jpg
Old 30th July 2012, 17:30   #357
e28s38b36
e28s38b36's Avatar
Just an update.
Have now completed just over 100 miles since the radiator was repaired & modified. I have this happy medium now where the temp needle sits at 11.30 min to 11.55 max.
11.30 is constant when the car is in motion at any speed. This includes driving slowly through town with frequent stops or 80-85 with the cruise control set on the motorway. The cooling fan is only really activated in town or after a long-ish run after coming to a stand still.
With the summer weather the UK has had over the past five days it has been a real pleasure to watch the car behave just like a standard item.
The size of the blanking plate I had welded to the radiator is spot on. The cooling fan is inoperative for 90% of the time
Petrol.... I'm using Tesco 99 octane all the time now. The engine just runs so much better on it than any other brand. I'm also getting really good mpg which is a real surprise!
Just joined :) A few pics of Babe.-100_3400.jpg
Old 5th August 2012, 12:17   #358
AseanAero
AseanAero's Avatar
Garage: 1990 E34 M5 Shwarz II
A great build , I enjoy reading this type of thread.
What always amuses me on the M5board is the photos of new parts in BMW packaging proudly displayed which is like car porn for all of us
Good stuff
AseanAero is online now   Reply With Quote
The Following User Says Thank You to AseanAero For This Useful Post:
e28s38b36 (11th August 2012)
Old 6th August 2012, 18:46   #359
Ferrari-Bmw
Garage: Alpina B10 Biturbo Ferrari Yellow
This fan you are using ,, were in the hell did you find this monster ,,,,,, like a Nuclear cooler
Sveinbjörn Hrafnsson
E30 CABRIO S3 8B38
ALPINA B10 BITURBO 346 @ 507
http://alpina.123.is/pictures/
Ferrari-Bmw is offline   Reply With Quote
Old 11th August 2012, 02:07   #360
e28s38b36
e28s38b36's Avatar
Fan is made by Kenlow. It's a twin speed unit. The most powerful version. If you look at the first few pages of the thread you will see it in more detail.
Joined Awhile Ago, but Time for Pics kaburke1 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 7 16th April 2010 09:46
My Brother ..Joined THE M-CLUB (PICS) dubai_m5 Owners Gallery 4 8th April 2007 01:50
My Brother ..Joined THE M-CLUB (PICS)+Z06 story dubai_m5 E60 M5 and E61 M5 Touring Discussion 9 23rd February 2007 22:24
My Brother ..Joined THE M-CLUB (PICS) dubai_m5 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 1 21st February 2007 15:12
Sorry Babe !! Nille E39 M5 and E52 Z8 Discussion 5 27th October 2000 21:50
