Just joined :) A few pics of Babe. - Page 27 - BMW M5 Forum and M6 Forums
Go Back   BMW M5 Forum and M6 Forums > BMW M5, M5 Touring, M6 and Z8 Forums > E28 M5 Discussion
E28 M5 Discussion 1984-1988
Like Tree56Likes
LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 18th August 2011, 22:15   #261
e28s38b36
e28s38b36's Avatar
Garage: 1986 e28 with s38b36 engine & gearbox, 380mm front, 360mm rear AP Racing brakes etc etc etc.
e28s38b36 is offline   Reply With Quote
Old 20th August 2011, 11:39   #262
Stoffie
Garage: BMW M635CSi Schwarz
Still an awesome project despite the setbacks! Keep on pumping money into that beast
It'll be so rewarding to finally drive your baby!
Stoffie is online now   Reply With Quote
The Following User Says Thank You to Stoffie For This Useful Post:
e28s38b36 (20th August 2011)
Old 20th August 2011, 13:01   #263
e28s38b36
e28s38b36's Avatar
Thank you very much
Just waiting on people now to pull there fingers out! IT WILL BE FINISHED BY THE END OF THIS MONTH or else!
Old 12th September 2011, 19:03   #264
e28s38b36
e28s38b36's Avatar
Update.
Dirt
Alpina clocks are wired in. Control boxes know live behind the tape storage unit. Sensor wires for diff temp wired into main harness. My homework paid off. Alpina oil canister lid fits with no modifications. Once again wires mated into the engine harness re-taped in BMW fabric tape.
Lower radiator/ chassis brace made.
Another update tomorrow.
Just joined :) A few pics of Babe.-10092011728.jpg
Just joined :) A few pics of Babe.-10092011717.jpg
Just joined :) A few pics of Babe.-10092011726.jpg
Just joined :) A few pics of Babe.-10092011727.jpg
Old 12th September 2011, 19:52   #265
e28s38b36
e28s38b36's Avatar
Forgot to say that the billet flywheel I bought off D has been fitted & throttle response is epic! The re-built gearbox works perfectly too so all in all progress has been made...even though another deadline has passed.
Making the trip Fritz tomorrow so hopefully things have moved on since these pictures were taken. I will see......................................
Old 12th September 2011, 23:09   #266
batmobile
batmobile's Avatar
Garage: M5 touring elekta british racing green; M5 e28 Alpine white
an e34/e36 Alpina instrument pod in a e28.. curious.
I' still waiting your answer... in the other topic.
Old BMWs never die!!!
batmobile is offline   Reply With Quote
Old 12th September 2011, 23:31   #267
e28s38b36
e28s38b36's Avatar
Originally Posted by e28s38b36 View Post
Well still waiting for the call on the gearbox! Problem seems to be the finish of the casing. I want show standard so it's going to take a little more time.
In the mean time I have been on the hunt for aux gauges to keep an eye on the vitals. There are lots of different gauges on the market to choose from but I decided to make my life a little more difficult & track down Alpina aux gauges! I like a challenge!!!
Obviously I would have liked to have tracked down a Alpina B7 Turbo gauge cluster but that is impossible so being the resourceful fellow than I am I have gone for the next best thing
With the below cluster I get digital oil pressure in Bar & Psi a well as differential temp!
Post 231.
www.kinnby.com
Old 13th September 2011, 07:42   #268
batmobile
batmobile's Avatar
Post 231.
www.kinnby.com
Ok, now i know why pf the cluster (there were this spring an e28 cluster on ebay.de, for only 240 Euros.. i didn't buy it only because A/C is more important than some infos, as the infos can be read in other places..)
The second link doesn't give me no information on what i asked.
Old 13th September 2011, 22:25   #269
e28s38b36
e28s38b36's Avatar
Nearly there.............................
Well just got back from Somerset...............
Had to modify the electric fan fixing points as the fixings on the radiator were starting to come loose!!! The thought of it coming adrift & hitting the bottom pulley had me in sweats!!! Fritz is blaming the fan stating that every time to switches on they think the car is going to move forward! There scared of it
The solution that Dave has come up with is much better than the previous. The fan is now fixed too the body of the car by way of 4mm thick steel bar top & bottom which will help stiffen up the front of the car no end. The bottom bar (Picture above) also acts as a brace for the bottom of the radiator to stop it moving back towards the bottom pulley.
The other plus point is that instead of having to remove the radiator & fan as a complete unit to get to the crank bolt all I will have to do now is remove four bolt to remove the fan for access while leaving the radiator in place. D will be happy because he will be adjusting my shims
The pictures attached are just the mock up..."Hay it works!" ones. It will look much better when finished.
Tried to fit my Alpina softlines on the front to see if they cleared the calipers........No luck....
Offered up the Hartge's & came across a little problem! When Hartge supplied the wheels they also supplied a shim of sorts that fitted inside the spigot hole.....When I bought the wheels I was not supplied with these shims .... What this means is that I am having to have custom aluminium ones made! I did call Birds BMW how are the UK Hartge parts suppliers but they were as much use as a chocolate fire guard!
Measurements have been taken & I have also supplied a wheel hub to the engineering firm. Should hopefully have them at some point next week. Will post pictures when I get them.
What a day! At least the electric seats & Alpina clocks are working! I really cannot wait to give the car a clean.............. Work shops are dirty places....
Just joined :) A few pics of Babe.-100_2966.jpg
Just joined :) A few pics of Babe.-100_2969.jpg
Just joined :) A few pics of Babe.-100_2970.jpg
Old 13th September 2011, 23:38   #270
davidoli
Hang in there Shaun ........... You'll have her back just in time for winter !
D
91 Sebring 3.6 | E28 UK RHD M5 | E34 UK RHD 3.8 | E34 M5 Touring | E24 M635CSi UK RHD
www.classicmdautos.co.uk
davidoli is offline   Reply With Quote
The Following User Says Thank You to davidoli For This Useful Post:
e28s38b36 (14th September 2011)
Joined Awhile Ago, but Time for Pics kaburke1 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 7 16th April 2010 09:46
My Brother ..Joined THE M-CLUB (PICS) dubai_m5 Owners Gallery 4 8th April 2007 01:50
My Brother ..Joined THE M-CLUB (PICS)+Z06 story dubai_m5 E60 M5 and E61 M5 Touring Discussion 9 23rd February 2007 22:24
My Brother ..Joined THE M-CLUB (PICS) dubai_m5 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 1 21st February 2007 15:12
Sorry Babe !! Nille E39 M5 and E52 Z8 Discussion 5 27th October 2000 21:50
