E28 M5 Discussion 1984-1988
Old 27th October 2009, 17:19   #1
hysteric
Garage: imaginary e28 M5
Rev counter isssues
Hi chaps - a query for the grizzly bearded M5ers ... my brother has just purchased his first E28 M5, and is still awaiting transfer however has been notfied the rev counter does not work. The batteries on the circuit board have been replaced with new ones and still no joy. I know Davidoli had similar experiences with Diamond Diana ?
Any thoughts on what could be the issue ?
Thanks again.
when trouble comes it comes not in single spires but in battalions.
hysteric is offline
Old 27th October 2009, 22:17   #2
M5Wagon
M5Wagon's Avatar
Garage: 2007 E61 M5 Touring, 1986 E28 M5 (RHD #77)
Sorry can't advise as i'm a newbie to the E28, but would love to hear more about the car - what number is it ??
M5Wagon is offline
Old 27th October 2009, 23:18   #3
hysteric
Hi. Its the very first to roll off the lines at Rosslyn in SA.
hysteric is offline
Old 27th October 2009, 23:23   #4
hysteric
Sorry.. and now hopefully with the pic!
Any thoughts or suggestions on the rev counter ladies and gentlemen ?
hysteric is offline
Old 28th October 2009, 00:06   #5
M5Wagon
M5Wagon's Avatar
Lovely !!!
Cheers,
David.
M5Wagon is offline
Old 28th October 2009, 07:16   #6
BMWWGN
Garage: 2000 528iAT Titansilber
Congratulations to your brother on the purchase.
I believe that was James Miller's car - a very nice example, with only 104,000 kms.
It must be time to update the E28 M5 registry - what with Bayerische sending his to Australia and this SA car going north to the UK.
I guess the score remains even, between northern & southern hemispheres!
Sorry can't help on the tacho problem.
Cheers
BMWWGN is offline
Old 28th October 2009, 11:52   #7
hysteric
Sounds like the southern hemisphere is coming up trumps because the car is staying in SA !!
It's just me staying in London for the weather!
hysteric is offline
Old 29th October 2009, 00:38   #8
Mfiver
Mfiver's Avatar
Garage: E28 M5 - Cirrus Blue - 1987
Rev Counter
I know it sounds very basic....but check the fuses first.
They need to be in perfect order - it's possible for the conductor to crack, which may not be visible without the aid of a magnifying glass. They are cheap so it's worth renewing them all - when new the conductor is a copper colour which quickly oxidises. Make sure the contacts in the box are clean, too.
If the cluster has been removed recently then it may be wise to check that all the plugs are correctly refitted.
Regards
Mfiver
Mfiver is offline
Old 8th November 2009, 21:14   #9
davidoli
In relation to my rev counter issue , the actual dial itself appears to be the problem .
I did manage to trigger a mini-revival prior to getting the batteries replaced , simply by removing the rev counter and giving the whole assembly a good spray of electrical contact cleaner .
This cure didn't last for more than a day or so though and new batteries did not resurrect the rev counter either !
Apparently one must take care with the fuel and temp guages when putting the instrument cluster back together , by easing them up to their upper needle levels immediately prior to reassembling the cluster , so that the needles return to their rightful place after assembly .
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 8th November 2009, 22:07   #10
hysteric
Thanks for the info David. Hope Diana is treating you well.
Cheers.
hysteric is offline
The Following User Says Thank You to hysteric For This Useful Post:
davidoli (8th November 2009)
Sticky rev counter gavinp E34 M5 Discussion 1 31st July 2006 20:53
Rev Counter m5-black E60 M5 and E61 M5 Touring Discussion 7 16th September 2005 00:02
Lights On Rev Counter wa1shy E39 M5 and E52 Z8 Discussion 15 22nd May 2004 12:15
Why only 5K RPM Rev Counter??? dNA3D E60 M5 and E61 M5 Touring Discussion 2 3rd April 2003 22:29
Rev Counter Operation dronfieldm E34 M5 Discussion 2 24th September 2002 12:04
Page generated in 0.12045 seconds with 12 queries
