E28 M5 Discussion 1984-1988
LinkBack Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 5.00 average. Display Modes
Old 24th October 2009, 22:41   #31
raymondw
raymondw's Avatar
During the last two evenings, the points on the todo list for reaching the already defined milestone were partially dealt with.
Prior to the installation of the starter engine, it has been inspected and cleaned. The brushes still have 50% life left so that is not a risk in years to come. The shaft has been cleaned and greased prior to its reassembly and reinstallation onto the engine block.
Another completed point is the water-pump-pulley. This part has been sandblasted, galvanized and powder coated, just like the PAS-pump pulley.
Before installing the oil-filter head, I had to remove the remains of the old gasket. Removing the 24year-old seal was not as straightforward as it appears. The surface of the mating area with the engine block must be flat as otherwise leaks occur. I also installed a new oil-pressure switch and a new ground-return lead (from the alternator).
The current status of the outstanding issues in this milestone is:
Completed issues:
1: Install main heat-shield between the exhaust manifold and the right front chassis-beam => Done (yellow arrow)
2: Install the oil-filter head and replace its oil-pressure switch => Done, (see picture above)
3: Reconnect the oil-cooler to the oil-filter head => Done, (orange arrow).
4: Install the clutch-slave cylinder and the sensors on the gearbox => Done (red and purple arrows)
5: Installed one of the tensioner-bar of the AC-pump => Done (green arrow)
6: Find a new spanner-rail for the AC-pump (potential showstopper for the milestone) => Pending.
Still to do:
1: Connect the reverse gear wiring-loom to the gearbox.
2: Fill engine with break-in oil (15W40 mineral) with new filter.
3: Install the exhaust system.
4: Torque the sub-frame-and suspension bolts to specification.
5: Installation of the radiator => This point will be moved to the following milestone.
Contemplations:
1: I am contemplating the replacement of the entire engine-wiring loom with a new part. This will save me the hassle of overhauling the old wiring loom.
Raymond
==> MY90 E34 M5 3.6 <==
==> MY85 E28 M5 M88/3 <==
The E34 M5 Alps tour. Sixth edition: 14-17 September 2007
raymondw is offline
The Following User Says Thank You to raymondw For This Useful Post:
corneredge (28th October 2009)
Old 24th October 2009, 23:31   #32
davidoli
Great progress Ray ....... Thanks for the update .
If the expense is not a limiting factor , then I believe that a new engine wiring loom would be a prudent step to take .
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 25th October 2009, 17:21   #33
2010Rph
Garage: Black bmw 540
keep up Ray. I like the attention to detail
2010Rph is offline
Old 26th October 2009, 21:16   #34
Dan Kelly
Garage: E34 M5 Sterling Silver
Hi Raymond, glad to see things are progressing nicely. I also wanted to replace the engine wiring harness on my E34 after numerous problems with the original part due to it being very brittle and not liking being moved about too much. Unfortunately the harness for early build E34 M5 (pre 08/90) is now NLA. I hope they are still available for E28 M5.
'90 E34 M5 3.6 Sterling Silver
'03 E39 540i Sport Touring Mora Mettalic
'95 E34 525i Petrol Mica SOLD
'05 KTM 990 superduke
Dan Kelly is offline
Old 27th October 2009, 22:19   #35
M5Wagon
M5Wagon's Avatar
Garage: 2007 E61 M5 Touring, 1986 E28 M5 (RHD #77)
Wow nice detailed thread, you have admirable patience my friend !!
Have a feeling i'll be seeing quite a lot of these scenes myself as i get through my restoration
Cheers,
David.
M5Wagon is online now
Old 4th November 2009, 21:41   #36
raymondw
raymondw's Avatar
I don't really want to repair the engine-wiring loom, so I bit the bullet yesterday and placed my order for a new engine-wiring loom. The system indicated a price of 462 Euro ex VAT so we didn't really expected it to be NLA. But fifteen minutes later this was confirmed by BMW Netherlands. Now I have no other choice then plan for a refurbishment of the existing wiring loom.
The good new is that the crank-sensor has become significantly cheaper and is available. The existing part has been damaged by some more-on in the past who covered-up his mistake. Not a very good idea as this causes a disruption in the shield and thus reduces the immunity against electro magnetic interference.
According to the parts catalogue the price is 209 Euro (ex VAT), but that has been reduced to 79 Euro ex VAT just recently. A no brainer if you ask me.
Raymond
raymondw is offline
Mfiver (5th November 2009)
Old 8th November 2009, 21:06   #37
davidoli
Keep up the quality work Raymond ....... you are so nearly there !
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 9th November 2009, 20:46   #38
raymondw
raymondw's Avatar
I was pleasantly surprized with the reduced price for a new crankshaft TDC sensor. Just 30 Euro ex VAT means a saving of roughly 180 Euro ex VAT compared to the old part. The downside is that the connector for plug-in to the engine wiring loom is not supplied. This means some hand-work.
This puts the condition of my old sensor in another perspective. I assumed it was damaged during previous engine work, but with the new knowledge in mind I can only conclude that BMW supplies the sensors without the connectors. This means you have to buy the connector-shell, the connector-pins as well. As I could not find these in teh ETK, nor could my dealer the only option is to cut the old connector and reuse it.
This must have been the problem of a previous owner as well as the longitudal cut in the heat-shrinkeble tube is man-inflicted. The quality of this work is very poor. My five-year old boy does a better job if I may say so.
I cut the old wires about 7mm from the connector shell. Removing the old connector pins will only result in damage so I decided against that. I stripped the leads roughly 3mm to find out the copper standed wires were corroded to such an extent that tin-leveling was not possible. I removed the oxidation with pure alcohol and tinned the leads with plain PbSn solder during which I manually added flux-solvent. With other words, not a simple process, but mandatory for resurecting these old wires.
After preparing the old wires, I connected the wires of the new-sensor to the old connector and isolated the individual wires with heat-shrinkable tubes (1608 type 50% crimp). When that was done, I isolated the joint with heat-shrinkable tubing as well (9547 type 50% crimp). This matches the old OEM finish.
This will provide for a reliable long-term solution for years to come.
Raymond
raymondw is offline
corneredge (12th November 2009)
Old 9th November 2009, 21:51   #39
Stoffie
Garage: BMW M635CSI Black
The quality of your work and the thoroughness of this install keeps amazing me Raymond!
Stoffie is online now
Old 15th November 2009, 00:16   #40
raymondw
raymondw's Avatar
The property class of a metric (carbon) steel bolt is indicated in two numbers separated by a dot. The first number before the point indicates the maximum tensile strength expressed in hecto-Newton per square millimeters. The second figure behind the dot indicates the ratio between the minimum yield stress and the minimum tensile strength, times ten. With other words, the commonly used 8.8 property-class has a minimum tensile strength of an 8.8 bolt is 800 N/mm2 and a minimum yield strength of 640N/mm2.
In the European automotive industry, property-class 8.8 is commonly used and where necessary (e.g. high stress), 10.9 or even 12.9 is applied, but 8.8 is the minimum. This rules out the general bolts that you can find in your local hardware store; these are generally no better then 4.6 or 4.8. These are OK for general non-critical applications, but generally not suited in cars.
This also is the reason why stainless steel bolts are not used in cars. Stainless steel has a much better resistance to corrosion then surface treated carbon steel, but does not have the high tensile strength from a steel bolt. However, for non-critical applications, stainless steel bolts may be used to rule out the concerns of corrosion. One such place is the crank-sensor. It is fitted with a single M5x12 bolt that can be fastened with 6.4Nm max. But 5Nm will also suffice and this allows the use of a stainless steel bolt of A2 property class. Do not use the commonly used A1-class as these allow less then 40% of the tensile strength of an A2 class bolt. The allowed 2.4Nm simply is too low, even for a simple sensor.
I also made a start with the overhaul of the engine wiring-loom by cutting the damaged section. The plan is to make an entirely new branch to length and solder it onto the engine-wiring loom. The branch that has been cut will be kept for future reference. It is needed for properly installing the connectors for the three temperature sensors.
From each wire, I cut a section of roughly 1cm in length to determine the exact color-coding. If possible, I will source new wiring with the same color-code.
To determine the condition of the copper stands, I stripped the insulation of one wire. Apart from the expected oxidation, the conductor is pretty much OK. This is good news as there is no need to strip the wiring-loom any further in this branch.
More worrying is the insulation of the main-supply lead for the starter-relay. The insulation is ******* due to aging and conductive losses, or simply heat. Even though that the operating voltage just is 12V+20% and the required creepage distance is less then the depth of the cracks, that is no more then a layman’s approach.
In reality, the load is inductive and during switch-off, the voltage will rise according to V = L*dI/dt. Depending on inductance of the load and change of current during the switching time (dI/dt), a voltage transient rising far above the battery voltage will be induced. This transient voltage can be in excess of several hundred volts and with the insulation damage, a break down to another conductor may occur. This can eventually lead to damage of electronic parts.
In fact, these cracks were the reason for me to prefer a new engine-wiring loom, but since these are no longer available, I need to replace the conductor. This requires the entire disassembly of the middle branch, which is much more difficult then replacing the branch for the temperature senders.
My plan is to create a list of the required parts and create a schematic of the circuit before further disassembly.
Last but not least the alternator; it has been replaced in the past as it lacks the BMW part numbers. It is however a genuine Bosch part. From a technical point of view, there is no need to replace it, but I do not like the corrosion on the pulley and the blades. A new alternator is 320 Euro from BMW and 240 from a Bosch specialist (rebates excluded).
The brushes still have enough life left in them, but they differ in length as can be seen on the following picture.
After removing of the pulley and the cooling-blade, the alternator looks pretty much OK and just needs some mild cleaning.
If the cooling bade and the pulley are available as separate parts, I will simply replace them together with the brushes and the interference suppression capacitor (22uF/100V).
Raymond
raymondw is offline
The Following 3 Users Say Thank You to raymondw For This Useful Post:
corneredge (15th November 2009), davidoli (16th November 2009), Mfiver (18th November 2009)
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
M5Wagon
Engine rebuild LHD #231 raymondw E28 M5 Discussion 172 2nd October 2009 01:35
Online project record LHD #231 (update on engine rebuild) raymondw E28 M5 Discussion 0 11th July 2009 12:31
E28S M5 #231, wrenching time => Engine rebuild (page 5). raymondw E28 M5 Discussion 89 31st May 2008 21:44
LHD #231 DME firmware analysis and investigation raymondw E28 M5 Discussion 5 13th September 2005 23:34
Help on EDC Switch installation on LHD 3,8 Jahangeer E34 M5 Discussion 4 10th June 2005 18:11
Page generated in 0.13759 seconds with 11 queries
