E28 M5 Discussion 1984-1988
LinkBack Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 5.00 average. Display Modes
Old 15th October 2009, 21:28   #21
raymondw
raymondw's Avatar
Originally Posted by Stoffie View Post
Had some rather annoying problems with my M88/3, cost a small fortune to fix, and I still feel like the engine does not idle the way it should. Intermittent vibrations to the interior, but maybe that's normal for these cars ? What's the correct idling speed for an M88/3 anyway ?
I will check this in my documents and report back in this thread. That reminds me that I have seen an Email from you in my inbox. I have read it, and hope to have a reply ready during the upcomming weekend.
Raymond
==> MY90 E34 M5 3.6 <==
==> MY85 E28 M5 M88/3 <==
The E34 M5 Alps tour. Sixth edition: 14-17 September 2007
raymondw is offline
Old 15th October 2009, 22:24   #22
Stoffie
Garage: BMW M635CSI Black
Hey raymond, that would be great. Didn't know if that email was still active, but I'm glad it is
Always looking forward to your posts!
Stoffie is offline
Old 16th October 2009, 02:11   #23
davidoli
[quote=raymondw;1661351]Work is slowly but steadily progressing. Yesterday evening, I finished the installation of the propeller-shaft to the gearbox. The hardy disk and the three M12 bolts were replaced in April 2008. As these have been used no more then 500km, I reused the hardy-disk and the bolts. The self-locking hex nuts have been replaced though. Unlike the E34S M5, the bolts are 8.8 rated. With other words, torque them at 81Nm instead of 110Nm.
Hi Raymond , great pics and narrative as usual ......thanks .
One quick point , the bolts on the hardy disc are directional , as indicated by the triangular arrows visible on the side of the disc . The head of the bolt being at the base of the triangle and the nut at the tip . Therefore , alternate bolts should be fitted in opposite directions .
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
The Following 4 Users Say Thank You to davidoli For This Useful Post:
corneredge (16th October 2009), fishy (16th October 2009), mottati (16th October 2009), raymondw (16th October 2009)
Old 16th October 2009, 14:52   #24
raymondw
raymondw's Avatar
Hey D,
I have checked the repair instructions and these match your statement. I will correct this at the next session. Thanks for the feedback.
Raymond
raymondw is offline
The Following User Says Thank You to raymondw For This Useful Post:
davidoli (16th October 2009)
Old 16th October 2009, 15:31   #25
raymondw
raymondw's Avatar
I have encountered another problem whilst installing the AC pomp. I orderded new spanner-brackets, but unfortunatelly one of them is no longer available.
This is not just a cosmetic repair as the idler-rail has been damaged beyond repair. My dealer checked the inventory-list in Holland and it is not available anymore.
I will check with some of the scrapers if they can help.
Raymond
raymondw is offline
Old 16th October 2009, 23:10   #26
davidoli
Ray , I may have one of these .
What are the dimensions ?
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 17th October 2009, 23:38   #27
raymondw
raymondw's Avatar
The following picture clarifies David’s point. The mounting holes of the hardy disk are directional and marked with an arrow that should point towards the respective mounting flange. I have marked the arrow by outlining it in blue.
The repair microfiche explicitly mentions this point, but for some reason, I missed the instruction whilst installing it in April 2008. Thanks Davidoli for pointing me to this. Furthermore; another member pointed me to the missing washer plates. Although it is a fact that washers prevent strain on the hardy disk itself, neither the parts catalogue nor the repair instructions mention that washers should be installed.
Next to this corrective measure, I finished some minor points like the pulley on the PAS-pump and the reconnection of the power steering hoses to the pump. The pulley still is the same part as before, but I had it sandblasted, galvanized and powder coated.
I have set a milestone for the end of October after which a temporary change in my private situation forces me to temporarily halt the work on #231. I have known this since last summer, but I have included this break in my planning Anyhow, the milestone is to finish all the required work that is needed to remove #231 from my four-column lift.
Still to do for reaching this milestone:
1: Install main heat-shield between the exhaust manifold and the right front chassis-beam.
2: Install the oil-filter head and replace its oil-pressure switch.
3: Reconnect the oil-cooler to the oil-filter head.
4: Fill engine with break-in oil (15W40 mineral) with new filter.
5: Find a new spanner-rail for the AC-pump (potential showstopper for the milestone).
6: Install the clutch-slave cylinder and the sensors on the gearbox.
7: Connect the reverse gear wiring-loom to the gearbox
8: Install the exhaust system.
9: Torque the sub-frame-and suspension bolts to specification.
10: Installation of the radiator.
I think this can be done in about two evenings.
Raymond
raymondw is offline
corneredge (20th October 2009)
Old 17th October 2009, 23:40   #28
raymondw
raymondw's Avatar
D
Hey David,
According to the ETK, this part is shared between all M30 or M88 powered E23, E24/1 or E28, so if you have any of these .
Raymond
raymondw is offline
Old 18th October 2009, 02:53   #29
Sebring NL
Sebring NL's Avatar
Exactly ray, looks the same as on the two M535i 's we have here.
On the E28 M5 with S38 that I maintain, its ofcourse a bit different
Oh, great work btw!
W
///M5HD91-229-
|Eibach|Koni|Porsche Brembo
for looking through the windscreen
///M535iDC71-181-
|H&R|Bilstein|Sparco
for looking through the Lexan side windows
B6 3.5 1531-668-
|Dogleg|Glanzschwarz
for fun
C1 2.5 1531-184-
|D-1 cage|full race spec
for looking at chequered flags
740d GE81-317-
twinscroll v8 diesel daily
Sebring NL is offline
The Following User Says Thank You to Sebring NL For This Useful Post:
raymondw (18th October 2009)
Old 18th October 2009, 10:52   #30
davidoli
Originally Posted by raymondw View Post
Hey David,
Sorry Ray , I only have the E34 variation .
p.s. I have never seen washers on the hardy disc fittings .
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Konfused Pete
Engine rebuild LHD #231 raymondw E28 M5 Discussion 172 2nd October 2009 01:35
Online project record LHD #231 (update on engine rebuild) raymondw E28 M5 Discussion 0 11th July 2009 12:31
E28S M5 #231, wrenching time => Engine rebuild (page 5). raymondw E28 M5 Discussion 89 31st May 2008 21:44
LHD #231 DME firmware analysis and investigation raymondw E28 M5 Discussion 5 13th September 2005 23:34
Help on EDC Switch installation on LHD 3,8 Jahangeer E34 M5 Discussion 4 10th June 2005 18:11
Page generated in 0.12826 seconds with 11 queries
