E28 M5 Discussion 1984-1988
Old 7th September 2009, 19:55   #1
fesuvious
Garage: E39 M5 in Blue
E28 M535I Tappets
Hello !!! I have migrated from the E39 board to the E28 board!
Hoping for some advice;
Is there an online resource for info on setting tappets? I have just accquired a 1987 M535I that has recently had a top end rebuild and now that she's bedded in the tappets are noisy as hell.
Have ordered a Haynes but its not here yet. Is there any info or good advice out there?
matt
fesuvious is offline
Old 8th September 2009, 14:09   #2
fishy
Garage: E 28 M5 Red
Hi Matt and welcome to M5 Board the Link below will take you to an online manual for the M30 engine as fitted to 635 CSI, same operation to check your valve clearances page 331, use the recommended figures from your handbook for feeler gauges
01 51 9 750 227 En - 026
Good Luck
Fishy
fishy is offline
Old 8th September 2009, 23:24   #3
fesuvious
Thanks, Thanks very much
To adjust each on:
You have to do them in order, and am I correct in assuming that when you adjust each one the corresponding piston should be at TDC? Iv never done this before.....
So, turn the engine to find TDC on each one and then adjust, right?
NOT have 1 at TDC and then adjust through the order
p.s check the clearance in the handbook? As in owners manual?
Old 11th September 2009, 10:24   #4
fesuvious
Il put a last post in case anyone in the future searches for 'tappets' and comes across this thread.
Adjusted them last night. Was advised to set them to either 12thou hot or 10thou cold. I set them cold.
Perfect !!!!!!
This setting is not whats in the Haynes but what Noel at NCB Autocraft advised. And he was right !
Tools req for the job
10mm spanner
10mm socket
small piece of wire for the adjuster
feeler guages
screwdriver or small socket for intake system
Large spanner to turn engine, if belts tight enough you can do what I did and turn off the fan nut.
It'll take 15 minutes to strip the parts to get to the tappets/rockers
@45 minutes for a newbie to adjust
@25 mins to put back together.
Old 12th September 2009, 18:54   #5
davidoli
Hi ,
I'm not so sure that your figures are correct .
IIRC the recommended tolerances for valve clearances on the M88/3 are 0.30 to 0.35mm and 12thou is approx 0.30mm i.e. on the tight side !
Valve clearances should always be measured cold .
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 14th September 2009, 22:45   #6
Stevie
Stevie's Avatar
Garage: e34 540i, Orientblau
He states M535i so M30 not M88/3. 12valve 30minute valve job......
Originally Posted by davidoli View Post
Hi ,
D
Dragracing a BMW is like taking Jessica Alba fishing. Some might considering it fun, but think of what they missed....
Stevie is offline
Old 15th September 2009, 01:19   #7
davidoli
You are right Stevie ........ Thanks m8 !
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
E28 M5 and M535i owner Jacko E28 M5 Discussion 4 29th January 2009 16:21
My E28 M535i racecar buildstory Sebring NL E28 M5 Discussion 9 18th June 2008 16:35
My E28 M535i with E34 M5 engine M535i Owners Gallery 5 15th August 2006 15:17
E28 M535i/535i Mfiver E28 M5 Discussion 4 27th November 2001 02:45
E28 M535i/535i Mfiver E28 M5 Discussion 3 6th November 2001 02:49
Page generated in 0.13576 seconds with 11 queries
