E28 M5 Discussion 1984-1988
Old 24th August 2009, 20:32   #1
Jimmy28m5
Garage: E28 M5 Zinnobar Red
rough idle when upto temperature...
Hi.My E28 M5 has developed the following problem...Starts up first time and runs perfectly when cold,but when it gets upto running temperature,from idling to about 2K revs it runs lumpy,(overfueling possibly?)
The AFM was replaced 2 years ago,today i replaced the blue temp sender on the water pipe above the exhaust manifold.
If anyones got any advice it would be most helpfull and appreciated...
Jimmy28m5 is offline
Old 25th August 2009, 10:07   #2
davidoli
The throttle position sensor is a potential suspect .
Has the fuel filter been renewed in recent history ?
Welcome to the forum and congratulations on acquiring a classic rare beauty !
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 12th September 2009, 09:37   #3
farrell
farrell's Avatar
Sales Feedback: (4)
It sounds like it ran ok when you first got it ?
Check the coolant sensors or wiring if occuring during idle speed control.
Temp time or temp constant feed to DME on coolant gallery,( not sender to instrument cluster)
hot side of engine or wiring to them is more likely the issue.
If not, I can pretty sure what it is if the above does not check out.
Cheers
Farrell
www.darjac-racing.co.uk
farrell is offline
rough idle bobsalotto E39 M5 and E52 Z8 Discussion 1 31st May 2007 02:27
Rough Idle/rough running at low revs Miksta E34 M5 Discussion 4 27th October 2006 09:56
Rough idle batmonger E34 M5 Discussion 13 26th October 2005 13:38
Rough idle on your M5??? Tim W E39 M5 and E52 Z8 Discussion 7 27th February 2002 07:05
Page generated in 0.08665 seconds with 11 queries
