E28 M5 Discussion 1984-1988
Old 21st August 2009, 16:35   #1
marekd174
Garage: 92 M5T , 85 M5
M88 valve clearance spec
Is the spec for the M88 motors the same as for the S38 motors, mainly 0.28-0.33mm or is it something else. I am going to check the clearances on my 85 M5 and need to know. The search function has not helped.
I know that the shims and tool are different from the S38 motors.
marekd174 is offline
Old 21st August 2009, 18:12   #2
raymondw
raymondw's Avatar
0,30mm - 0,35mm (@ cold engine)
Raymond
==> MY90 E34 M5 3.6 <==
==> MY85 E28 M5 M88/3 <==
The E34 M5 Alps tour. Sixth edition: 14-17 September 2007
raymondw is offline
The Following User Says Thank You to raymondw For This Useful Post:
davidoli (22nd August 2009)
M88/3 valve spring risk. raymondw E28 M5 Discussion 1 22nd July 2009 00:00
Piston to Valve clearance..... Sub8 E34 M5 Discussion 0 10th June 2009 13:25
For Sale For sale M88/3 Valve/rocker cover Bayerische For Sale or Wanted 0 6th June 2009 01:30
Help me- M88 valve clearances....15 shims reqd farrell E28 M5 Discussion 16 2nd March 2008 13:19
Valve Clearance procedure Usual Suspect E34 M5 Discussion 4 20th November 2007 19:20
Page generated in 0.08954 seconds with 11 queries
