E28 M5 Discussion 1984-1988
Old 12th July 2009, 22:24   #1
RHD #13
Garage: UK E28 M5 no.13 Diamond Black
Macpherson struts
As mechanic Rob has been going through the front end of the car since last weekend's unfortunate mishap, he's noticed that the inside walls at the top of the front tyres are almost rubbing against the struts...
I'm finding it hard to believe given the severity (or lack of) of my brief run up the verge of a country lane could've bent the stub axle's up... but it seems the only possible cause?
Any thoughts? Are the struts standard to all e28s? Anyone have a pair?
Cheers all
Tim
RHD #13 is offline
Old 14th July 2009, 22:39   #2
fishy
Garage: E 28 M5 Red
Hi Tim,
I would suggest that you may be better going for one of these laser alignment jobbies !, never have myself but when i bought my vehicle there was a report from one in the service history & its pretty comprehensive front & rear alignment & also front & rear camber which would pick up anything that was damaged or bent !!!
Got to be cheaper than buying suspension bits on spec or guessing just check all your tyre pressures book it in & hope for the best
Cheers
Fishy
fishy is offline
Old 24th July 2009, 18:47   #3
RHD #13
Thanks fishy, there's definitely a problem with the lower part of the struts, I've found some good replacements though which will be going on very soon.
I think I'll have the laser alignment treatment after though to make sure all is straight and as it should be.
RHD #13 is offline
new struts Emmasis E39 M5 and E52 Z8 Discussion 1 14th April 2009 18:30
Struts question malexgcab E39 M5 and E52 Z8 Discussion 2 20th August 2008 07:56
EDC struts are there but no wiring to it!!! Crash & Burn E34 M5 Discussion 4 19th January 2008 15:02
FS: Koni ADJ. Struts 97-03 540/M5 tilly42069 For Sale or Wanted 3 19th June 2007 04:22
Struts and Balljoints tranck E39 M5 and E52 Z8 Discussion 10 14th January 2007 10:04
Page generated in 0.08885 seconds with 11 queries
