E28 M5 Discussion 1984-1988
Old 23rd June 2009, 23:51   #1
batmobile
batmobile's Avatar
Garage: M5 touring elekta british racing green; M5 e28 Alpine white
Erratic Idle M88/3
for the idel check the temp sensors
Old BMWs never die!!!
batmobile is offline
Old 24th June 2009, 04:53   #2
Bayerische
Bayerische's Avatar
Garage: E28 M5 Diamond Black, E24 M635Csi Dolphin Grey
Welcome to the board RHD#13,
Glad to hear your car has found a new enthusiastic home. Plenty of good advice here on the board. I wish i could help with your erratic idle problem as I have a similar issue. When the engine is cold it idles fine, but when hot it idles at 1500rpm and then goes back to 700-750 rpm. I even replaced the AFM but it did not solve the problem.
I will try your suggestion of the temp sensors Batmobile, where are they located?
Post some pics when you get a chance and best of luck with your new purchase.
Bayerische
Bayerische is offline
Old 24th June 2009, 15:48   #3
Bayerische
Bayerische's Avatar
Thanks Batmobile much appreciated,
I think I will replace the temp sensor No.11 and see if that makes a difference.
O/T How is your E28 M5 restoration coming along? I am sure we would all love to see photos of your progress, if you have started it.
Bayerische
Old 24th June 2009, 17:48   #4
raymondw
raymondw's Avatar
I am not going to rule out the temp sensors, but these generally are not the cause of an arratic idle. I hope that with the replacement AFM, you also adjusted the CO to 1,5% with the adjustement screw on the AFM? Bear in mind that the M88/3 has a center adjustment screw in teh middle of the TB's for cyl #3 and cyl #4 that controls the idle speed.
Furthermore, there is an idle control valve underneath the TB's that may be contaminated. A simple clean-up with carburetter fluid may solve the problem.
Add to that, the possibility of hair-line cracks in the hoses attached to it, especially around the hose-clamps. Last but not least, there is a 7th injector on the TB's of the M88/3 that is connected with a hose to the fuel-distribution rail. This part has an O-ring that may have dried out. This injector is connected to a bypass system that functions when all the TB's are fully closed, i.e idle mode. There are five O-rings in this system that may have dried out.
Raymond
==> MY90 E34 M5 3.6 <==
==> MY85 E28 M5 M88/3 <==
The E34 M5 Alps tour. Sixth edition: 14-17 September 2007
raymondw is offline
Old 24th June 2009, 22:04   #5
Blackfox
Garage: E28 M5, Diamond Black
I think the temperature sensors sits behind the front bumper, I am sure there are many experts on the forum who can confirm/deny this. The OBC readout is generally accurate and consistent when travelling so I assume it must be subject to some heatsoak when stationary for a period on a hot day.
I have a substantial (£30k) history file for #16 and can also find no mention of any gearbox work, must have been a good batch when ours were built!
Blackfox is offline
Old 25th June 2009, 13:57   #6
Bayerische
Bayerische's Avatar
Erratic Idle M88/3
My car suffers from erratic idle when hot.
When the car is started from cold and when warming up it idles very smoothly at around 700-750 rpm. When hot, the idle seems to hang around 1500rpm. I usually dab the throttle a couple of times and is seems to come back to to 750rpm.
It seems number of other people on the forum have this problem, I am determined to get mine sorted out.
I replaced the AFM in the hopes this would solve the problem but no joy. The AFM was correctly set up for 1.5% CO.
From a previous thread, Batmoblile suggested that it may be the water temp sensor that is causing the problem. I will investigate this possibility Batmobile.
Raymond also posted this useful post.
"I am not going to rule out the temp sensors, but these generally are not the cause of an arratic idle. I hope that with the replacement AFM, you also adjusted the CO to 1,5% with the adjustement screw on the AFM? Bear in mind that the M88/3 has a center adjustment screw in teh middle of the TB's for cyl #3 and cyl #4 that controls the idle speed.
Add to that, the possibility of hair-line cracks in the hoses attached to it, especially around the hose-clamps. Last but not least, there is a 7th injector on the TB's of the M88/3 that is connected with a hose to the fuel-distribution rail. This part has an O-ring that may have dried out. This injector is connected to a bypass system that functions when all the TB's are fully closed, i.e idle mode. There are five O-rings in this system that may have dried out."
Old 25th June 2009, 14:05   #7
Bayerische
Bayerische's Avatar
I have a feeling that it may be the o rings around the 7th injector that is cauing the problem.
Which O rings are you talking about Raymond, and is the idle control valve easy to access?
All help much appreciated.
Bayerische
Old 25th June 2009, 14:51   #8
raymondw
raymondw's Avatar
Position 15, but there are others as well, but those are shown in a different parts group (TB's)
Raymond
raymondw is offline
Old 25th June 2009, 16:46   #9
Bayerische
Bayerische's Avatar
Thanks, unfortunately no.15 is no longer available. Where is the ICV located? I was under th impression that the M88 did not have an ICV.
What other seals/rings do you sugest replacing or checking?
Old 25th June 2009, 17:27   #10
raymondw
raymondw's Avatar
The ICV is position number 9. But also consider pos 13 and pos 17 (hoses).
Position #15 are the bypass screws for the CO. Do not touch them unless you know what you are doing.
Position number 15
Raymond
raymondw is offline
Erratic idle - Control Unit Air Accumulator Flap Izamn E34 M5 Discussion 0 16th September 2008 07:59
Erratic Temp Gauge Brett_M5 E39 M5 and E52 Z8 Discussion 5 7th July 2008 03:25
Erratic temp gauge ktmking E34 M5 Discussion 3 29th April 2007 14:18
Erratic Cold Idle Speed milesr3 E34 M5 Discussion 1 28th September 2006 18:06
Erratic Cellular Performance HadE55NowM5 E39 M5 and E52 Z8 Discussion 0 14th December 2000 07:56
Page generated in 0.19986 seconds with 11 queries
