'88 M5 - Oil in throttle body air box - BMW M5 Forum and M6 Forums
Go Back   BMW M5 Forum and M6 Forums > BMW M5, M5 Touring, M6 and Z8 Forums > E28 M5 Discussion
E28 M5 Discussion 1984-1988
Old 12th February 2002, 01:14   #1
TXVTX
Garage: 1988 M5
All,
I am trying to help a friend who owns a beautiful 1988 M5.
There appears to be an air expansion box that attaches to the six throttle bodies and has source air from the regular air box.
This box is LOADED with engine oil which of course is causing major amounts of blue smoke out the exhaust. There also appears to be an electronically controlled valve (PCV) just below the #2 and #3 throttle bodies that I believe may be the source of allowing enough vaccum to draw oil out of the valve cover and into this air expansion box and then directly right into the throttle bodies.
We have no manual (same on us) but are seeking the insight from you all.
One call to a BMW Service writter leads me to believe that this is an electronically controlled PCV valve and that it is bad but yet a call to the parts department the guy there states that this is an Idle Control Valve.
In either case, can this cause the large amounts of oil into this airbox?
Thanks,
Al
TXVTX is offline   Reply With Quote
Wooo tfung gone off deep end... EBMCS03 Off Topic Forum 4504 25th April 2011 22:04
German AMS magazine tests M5 suspension kits lofstrom E39 M5 and E52 Z8 Discussion 25 11th April 2008 12:24
Long and technical: thoughts on cold air intakes and temp sensor relocation greg E39 M5 and E52 Z8 Discussion 48 4th August 2006 09:23
BMW M5 culture over the net Rodrigo Feher E39 M5 and E52 Z8 Discussion 8 22nd December 2003 01:04
