E28 M5 Discussion 1984-1988
Old 3rd June 2009, 18:15   #1
fishy
Garage: E 28 M5 Red
Outside Temperature Sensor
Hi Folks
Just arrived back after 5 weeks & find the temp on the OBC is reading minus 22 - Its not a sunny day here in Scotland but dont think its That bad
Can anyone tell me where the sensor is located on the vehicle so i can first check connections etc (it was ok when i left) thinking this could be a default reading if no circuit
Any suggestions appreciated as always.
Cheers
Fishy
fishy is offline
Old 5th June 2009, 12:47   #2
fishy
Garage: E 28 M5 Red
Bump ?
Anyone with a Bentley manual ?
Cheers
Fishy
fishy is offline
Old 5th June 2009, 23:40   #3
davidoli
Hi Fishy ,
Look in the front bumper ......
Item 14 in this diagram shows it :
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
The Following User Says Thank You to davidoli For This Useful Post:
fishy (6th June 2009)
Old 6th June 2009, 12:27   #4
fishy
Garage: E 28 M5 Red
David
Thanks i should have thought of checking OEM myself
will check it out this weekend
Cheers
Fishy
fishy is offline
Old 3rd July 2009, 16:59   #5
Wallacewhitlock
Wallacewhitlock's Avatar
Garage: 02 M5 Titanium Silver Metallic
Did you find a way to reset you thermo reading? Mine is about 10 degrees high....and curious if there is an easy way to reset. The external thermostat is located in front of your passenger front tire.
Wallacewhitlock is offline
Old 4th July 2009, 03:15   #6
fishy
Garage: E 28 M5 Red
Wallace, never had to do any resets i just replaced my sensor with one off an old 528i that i have sitting at home for body spares.
Bottom line was Temp reading appeared back as per normal & seems to be accurate ( But ? could also have been a connection problem as it is awkward to reach i never tried with the original sensor )
Dont know about USA but UK vehicles connector is clipped on down beside the Rad on LH looking forward & for vehicles with the Tech body kit the sensor is in the brake cooling duct.
Hope it helps
Cheers
Fishy
fishy is offline
Outside temperature sensor? Diny E39 M5 and E52 Z8 Discussion 22 1st March 2008 02:48
Which temperature sensor does the ECU use? rigsby E39 M5 and E52 Z8 Discussion 4 23rd August 2006 01:21
Would a bad temperature sensor cause this? rigsby E39 M5 and E52 Z8 Discussion 4 8th August 2006 11:23
Is this my temperature sensor? Davido164 E39 M5 and E52 Z8 Discussion 8 7th August 2005 09:39
Oil temperature sensor M540i LE E34 M5 Discussion 2 31st July 2004 02:06
Page generated in 0.10360 seconds with 11 queries
