BMW M5 Forum and M6 Forums (http://www.m5board.com/vbulletin/)
-   E28 M5 Discussion (http://www.m5board.com/vbulletin/e28-m5-discussion/)
-   -   Outside Temperature Sensor (http://www.m5board.com/vbulletin/e28-m5-discussion/138568-outside-temperature-sensor.html)
fishy 3rd June 2009 05:15 PM
Hi Folks
Just arrived back after 5 weeks & find the temp on the OBC is reading minus 22 ?????? - Its not a sunny day here in Scotland but dont think its That bad :cool2:
Can anyone tell me where the sensor is located on the vehicle so i can first check connections etc (it was ok when i left) thinking this could be a default reading if no circuit
Any suggestions appreciated as always.
Cheers
Fishy
fishy 5th June 2009 11:47 AM
Bump ?
Anyone with a Bentley manual ?
Cheers
Fishy
davidoli 5th June 2009 10:40 PM
Hi Fishy ,
Look in the front bumper ......
Item 14 in this diagram shows it :
http://www.realoem.com/bmw/diagrams/c/s/21.png
fishy 6th June 2009 11:27 AM
David
Thanks i should have thought of checking OEM myself ouich
will check it out this weekend
Cheers
Fishy
NCM5Guy 3rd July 2009 03:59 PM
Did you find a way to reset you thermo reading? Mine is about 10 degrees high....and curious if there is an easy way to reset. The external thermostat is located in front of your passenger front tire.
fishy 4th July 2009 02:15 AM
Wallace, never had to do any resets i just replaced my sensor with one off an old 528i that i have sitting at home for body spares.
Bottom line was Temp reading appeared back as per normal & seems to be accurate ( But ? could also have been a connection problem as it is awkward to reach i never tried with the original sensor )
Dont know about USA but UK vehicles connector is clipped on down beside the Rad on LH looking forward & for vehicles with the Tech body kit the sensor is in the brake cooling duct.
Hope it helps
Cheers
Fishy
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
