E28 M5 Discussion 1984-1988
Old 31st May 2009, 23:35   #1
hysteric
Garage: imaginary e28 M5
e28 m5 transmission
Hi all. Does anybody know if there is any other BMW gearbox that is a subsitute for the one found in an e28 m5 - ie same ratios and a direct swop?
And if not, what is the original gearbox for these cars ? Sorry for the newbie question!
My brother has come across a stranded M5 (not in the UK) that is stuck in 1st gear and wont budge!
Cheers.
when trouble comes it comes not in single spires but in battalions.
hysteric is offline
Old 1st June 2009, 00:44   #2
davidoli
The gearbox is the Getrag 280/5 and is the same as that fitted to the E24 M635 CSI .
Taken from BMW M Registery website :
All E28 M5s have the Getrag 280/5 five-speed manual gearbox. Gear ratios are as follows: 3.51 (1), 2.08 (2), 1.35 (3), 1.00 (4), .81 (5).
What kind of gearbox does the E34 M5 have?
All M5s built before May of 1994 utilize a Getrag 280/5 five-speed manual gearbox with the following ratios: 3.51 (1), 2.08 (2), 1.35 (3), 1.00 (4), 0.81 (5).
This would suggest that an early E34 M5 Getrag 280/5 gearbox could be fitted to an E28 M5 but I have never actually done so .
Perhaps , some of our more esteemed members could confirm ?
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 1st June 2009, 13:45   #3
hysteric
Thanks mate. The 280/5 I assume is the dogleg?
From my understanding, the dogleg is not the most favoured of gearbox's - if starting from a clean slate, what gearbox/transmission would people on this forum install in an E28 M5 in trying to keep it as original as pssible in terms of ratios but improving what may have been a flawed design with hindsight.
Cheers !
hysteric is offline
Old 2nd June 2009, 02:20   #4
Bayerische
Bayerische's Avatar
Garage: E28 M5 Diamond Black, E24 M635Csi Dolphin Grey
There was never a dogleg gearbox in the E28 M5 as far as I know. They all have a standard pattern box. I believe the dogleg box was only offered on the M535i.
Bayerische
Bayerische is offline
Old 2nd June 2009, 11:43   #5
alicante M5
Garage: E28 M5 lhd black
M5 geabox options
there's a thread on mye28.com on fitting a getrag 260 which may be of help if a 280 can't be found
alicante M5 is offline
Old 7th June 2009, 01:12   #6
286bhp
286bhp's Avatar
Garage: '00 735i Blue
You can't fit an E34 Getrag 280 to an E24/E28 as it is missing the holes for the speed / rpm sensors in the bell housing, however, the early 'box can be fitted to the later cars. I've had to do this on a few occasions when an E34 box has been beyond economical repair. If you are stuck , a 260 overdrive from an 84 -> 535i/635i will fit, provided all the external selector parts are swapped with it. The prop will need to be extended on it's splines about 25mm too - you will need to check if there is adequate length on the splines to accommodate this extension safely !
HTH
Phil
'02 M5 Lemans / Silverstone
Milltek Full system with 100 cell racecats
286bhp is offline
The Following 2 Users Say Thank You to 286bhp For This Useful Post:
Bayerische (7th June 2009), davidoli (7th June 2009)
Old 7th June 2009, 12:26   #7
hysteric
Thanks for the useful post mate. Much appreciated.
hysteric is offline
Old 7th June 2009, 14:15   #8
hysteric
Hi, me again - does anybody know of a getrag 280/5 rebuilder or specialist in South Africa ?
Main Stealer SA is not much help in this case !! thanks !
hysteric is offline
Old 7th June 2009, 15:55   #9
alicante M5
E28 M5 gearbox options - use a 265
my memory was wrong, it's a 265 the mye28 thread refers to, not a 260
MyE28.com: BMW E28 5-series Resource - View topic - Getrag 280 to 265 in an M5
probably easier than finding a 280, and cheaper than rebuilding one
looks like you need a late (85 and on) 535
Need a new transmission HDClown E39 M5 and E52 Z8 Discussion 20 26th January 2008 18:52
WTB: e36 m3 transmission! Omar For Sale or Wanted 2 15th March 2006 10:09
transmission Hercules E39 M5 and E52 Z8 Discussion 2 10th August 2004 15:49
E60 M5 Transmission MOHD HAJRI E60 M5 and E61 M5 Touring Discussion 12 4th April 2002 03:30
What oil shall I use for the transmission? Morten E34 M5 Discussion 3 18th August 2001 18:21
Page generated in 0.13564 seconds with 11 queries
