E28 M5 Discussion 1984-1988
Old 22nd November 2008, 19:00   #1
gjy
Garage: m5 e28 black
brake calipers
hi guys
im in the process of sorting out the brakes on my e28,done the back calipers and hand brake with no real problems to speak off,now im doing the front.having taken off the wheel its obvious that the calipers are seized and the seals are beyond repair so instead of messing around freeing the calipers and fitting new seals im going to buy a new/second hand pair,is it possible to fit e34 or e32 calipers?
gjy is offline
Old 23rd November 2008, 01:01   #2
davidoli
Originally Posted by gjy View Post
hi guys
Hi , yes , you can fit the 315mm front discs and single pot ATE calipers from the 3.6 E34 M5 and early pre 94 3.8 M5 under standard 16" E28 M5 wheels .
There are also many other options , but I am aware that you have been offered a set of E34 M5 brakes from one of your posts on the E34 forum .
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
The Following User Says Thank You to davidoli For This Useful Post:
gjy (23rd November 2008)
Old 23rd November 2008, 21:32   #3
gjy
hi davidoli
you seem to know your stuff so i wondered if you could help me out?as you have probably gathered im trying to restore a m535i that was given to me and having to upgrade the brakes to e34 m5,s i striped all the discs and calipers ready for when i get hold of a set.but ive noticed that the rear hubs are still quite difficult to turn even without any brakes what so ever on the car,is this the norm or could the diff be on the way to seizing too?
gjy is offline
Old 23rd November 2008, 21:56   #4
davidoli
Hi gjy , everyone seems to know their stuff in the wonderful world of the internet ......but thank you for the compliment !
The fact that the M535i that you are restoring has been sitting around for a while will not assist any of the moving parts to rotate freely , so I wouldn't assume that the lsd is about to seize .....you can always replace the diff oil as a precautionary measure and check that the drive shafts and wheel bearings are sufficiently well greased .
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 24th January 2009, 00:34   #5
paulvdree
Garage: M5 E28, Lachssilber Metallic
Hi, I'm also wanting to rebuild the front brake calipers of my E28 M5. I have obtained the rebuild kits contaning seals and dust caps, but unfortunately brake pistons are not separately available. The chrome layer has corroded around edge on some pistons, so I want to replace then. I want to keep the stock brake setup. Does anyone have an alternative source for these pistons or for having them rechromed?
paulvdree is offline
Old 24th January 2009, 01:03   #6
davidoli
Hi and welcome to the forum Paul .
Fellow board member Cecotto had a source :
M635/E28 M5 front caliper pistons
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 24th January 2009, 02:26   #7
Bayerische
Bayerische's Avatar
Garage: E28 M5 Diamond Black, E24 M635Csi Dolphin Grey
The last time I spoke to this breaker, he had some calipers from an e28 M5 that he had broken for parts. It was a while ago now, but it might be worth a phone call.
Quality Used BMW 'M' Power Parts - Breaking Now
Bayerische
Bayerische is offline
Old 24th January 2009, 12:10   #8
davidoli
If he wants a used set , then I have a pair of original E28 M5 calipers here , after putting the single pot E34 M5 ATE calipers on Diamond Diana .
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Brake calipers for sale BryanM E34 M5 Discussion 4 19th June 2008 10:42
Painting the Brake Calipers? TampaLBOs E60 M5 and E61 M5 Touring Discussion 16 6th November 2007 01:01
brake calipers bodein67 E60 M5 and E61 M5 Touring Discussion 7 20th January 2007 01:21
New brake calipers on eBay? Geach For Sale or Wanted 35 18th August 2006 22:48
Rebuilding the Brake Calipers ilovemy_e34 E34 M5 Discussion 2 24th March 2006 00:07
Page generated in 0.12616 seconds with 11 queries
