E28 M5 Discussion 1984-1988
Old 3rd January 2002, 05:26   #1
scotta1
Garage: '88 M5
Oil Leak from front of engine under head
1988 M5-New to M5 and have an oil leak on passenger side under head, coming from something I cannot identify . It protrudes and has round disk. It is over the air conditioner compressor. Leaks pretty good(1qt per 200 Mi), and seems to have no purpose. What is this thing? Is there anyplace on the net where I can get an exploded view of the M5 engine?
Thanks,
Scott
scotta1 is offline
Old 3rd January 2002, 11:33   #2
raymondw
raymondw's Avatar
Hello,
Everything on the M88/3 and S38 engines have a function. To really help you, you have to be more specific, but I think that you have one of the following problems:
1: The chain guides are mounted with unsealed bolts through the timing chain house. In time these can get loose. Check these.
2: Leaking gaskets between the front cover and the engine block.
3: The bolts which mount the front cover to the engine block are loose.
4: Leaking gasket between the cylinder head and the front cover. This is the cylinder head.
5: Failing tensioner.
6: Front Cranckshaft seal leaks.
Good luck,
Raymond
raymondw is offline
Old 3rd January 2002, 16:22   #3
scotta1
Garage: '88 M5
M5 oil leak
Thanks Raymond, But the leak is comming from some apendage on the upper block in front(passenger side). My mechanic, who is familiar W/e28 but not M5 has no clue to what this is. It is definatly on the pressure side of the oil galleries. It is not electrical and seems to have no mechanical function.
Mystery?
Thanks,
Scott
scotta1 is offline
Old 3rd January 2002, 16:37   #4
mikek
Garage: 530i
i can usually get exploded printouts from my BMW dealer of most M5 items. I think if you ask nicely they will oblige. Or take it to a dealer and ask for a quote for the work to be done. They will have to tell you wats involved in the job, and you dont have to let tehm do the work!!! easy!!
Regards
Mike K
mikek is offline
Old 3rd January 2002, 18:03   #5
scotta1
Garage: '88 M5
It is the tensioner. Thanks for the help.
Scott
scotta1 is offline
Old 3rd January 2002, 20:18   #6
mikek
Garage: 530i
Is it an engine out job to change the tensioner???
Regards
Mike K
mikek is offline
Old 3rd January 2002, 21:41   #7
scotta1
Garage: '88 M5
No, it is not out of car. but I am not deeling with it, since it is cold as $#@& outside, and my garage is full. The M5 is also somewhat a sore spot with the wife, being an expensive toy
Scott
scotta1 is offline
Old 3rd January 2002, 21:46   #8
mikek
Garage: 530i
yeah, Woman and M5's don't mix!!! hahaha
Regards
Mike K
mikek is offline
Old 4th January 2002, 00:11   #9
raymondw
raymondw's Avatar
And I have two M5's, a wife and a baby comming. My wife loves the ///M5, but not the cost of it's maintanance.
Raymond
Three little babies, two mechanical and one child coming in februari.
1990 E34 ///M5 3.6
1985 E28 ///M5 M88/3
raymondw is offline
Old 7th January 2002, 07:35   #10
Seninha
Seninha's Avatar
Garage: 88 M5 Black/tan
its funny how anything worth having is worth the sacrifice, isn't it?
88 M5
99 M3
Seninha is offline
Nowack Tuning Report, The Truth (Long Version) CharlesW E39 M5 and E52 Z8 Discussion 62 28th December 2009 22:44
Nowack Tuning Report, The Truth (Long Version) CharlesW Most Memorable Threads' 44 30th November 2002 05:49
Interview with Vögele, head of engine development and Himmproject head for the BMWel, Gustav E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 3 11th March 2002 22:40
A lot of oil under my engine Vince5 E39 M5 and E52 Z8 Discussion 3 19th February 2002 17:53
Page generated in 0.16106 seconds with 11 queries
