SpeedFreak Detailed: "Shopper1590"s 16k mile Interlagos Blue M5 resurrection! - BMW M5 Forum and M6 Forums
Go Back   BMW M5 Forum and M6 Forums > General Forums > Detailing Forum
Like Tree3Likes
Old 21st August 2012, 04:08   #1
SpeedFreak81
Garage: '88 Porsche 951
Hey guys! Very excited about this post, as the transformation throughout was truly a sight to see. I was contacted by Gunnar, "Shopper1590" to do some work on his Interlagos Blue M5. What a beautiful color it is, my all time favorite on these M cars. The vehicle in question is a 2006 model year with barely 16,000 miles on the odo. Gunnar picked the car up in April from a dealer who had obviously "attempted" to run a buffer over it.
After I viewed the car in the sun, we went over various plans of attack and settled on a full multi stage correction. Once the correction was complete, the work was locked in and protected with Optimum's Opti Coat.
The pictures will show the extent of the damage inflicted by the unskilled stealership employees. RIDS (Random-Isolated-Deep-Scratches), rotary buffer swirls, even pigtails were present in some areas from grit trapped under their buffing pad. Speaking of RIDS, they were abundant on every single panel, and the paint was very hard. The defect removal portion of the correction was probably the longest of any car I have worked on, and required almost 30 hours. I was making 5-7 passes per panel to fully remove the RIDS. That is just the first, compounding stage.
As they say, a picture is worth a thousand words.......which begs the question, how many words are 100 pictures worth???? You be the judge.
PRODUCTS USED:
  • Griots HD wheel cleaner
  • Meguiar's APC
  • CG Citrus wash
  • Pinnacle speed clay
  • DoDo Juice born slippery clay lube
  • M105 on Lake Country PFW pad via FLEX 3401
  • Pinnacle Advanced Finishing Polish on LC CCS white pad via FLEX 3401
  • Menzerna PO85RD (SF4500) on LC CCS Grey pad via FLEX 3401
  • Optimum metal polish
  • Wolfgang Black Diamond tire gel
  • Stoner Invisible Glass
  • Optimum Opti Coat
  • Poorboy's wheel sealant
Quick shot of the clay....pretty dirty
DSC_0739 by SpeedFreak81, on Flickr
Starting with the hood
DSC_0731 by SpeedFreak81, on Flickr
Swirling and RIDS present near windshield
DSC_0733 by SpeedFreak81, on Flickr
Pigtails previously mentioned
DSC_0734 by SpeedFreak81, on Flickr
Water spots and mineral deposits etched into the clear
DSC_0735 by SpeedFreak81, on Flickr
rotary installed swirling!
DSC_0736 by SpeedFreak81, on Flickr
More RIDS and swirls on passenger side
DSC_0737 by SpeedFreak81, on Flickr
DSC_0738 by SpeedFreak81, on Flickr
Driver's side hood after M105 on PFW, what a difference!
DSC_0740 by SpeedFreak81, on Flickr
DSC_0741 by SpeedFreak81, on Flickr
RIDS before
DSC_0743 by SpeedFreak81, on Flickr
Gone!
DSC_0745 by SpeedFreak81, on Flickr
After the hood I moved on to the trunk lid, which was especially bad
DSC_0746 by SpeedFreak81, on Flickr
DSC_0747 by SpeedFreak81, on Flickr
DSC_0750 by SpeedFreak81, on Flickr
Working on some 50/50s
DSC_0752 by SpeedFreak81, on Flickr
DSC_0754 by SpeedFreak81, on Flickr
DSC_0753 by SpeedFreak81, on Flickr
Compounding completed
DSC_0759 by SpeedFreak81, on Flickr
DSC_0761 by SpeedFreak81, on Flickr
DSC_0758 by SpeedFreak81, on Flickr
DSC_0756 by SpeedFreak81, on Flickr
Driver's side fender before
DSC_0764 by SpeedFreak81, on Flickr
DSC_0765 by SpeedFreak81, on Flickr
50/50
DSC_0768 by SpeedFreak81, on Flickr
50/50 driver's side front door
DSC_0770 by SpeedFreak81, on Flickr
DSC_0771 by SpeedFreak81, on Flickr
Defects removed! David of ProShield films surveys the work
DSC_0772 by SpeedFreak81, on Flickr
DSC_0773 by SpeedFreak81, on Flickr
Driver's rear door before
DSC_0775 by SpeedFreak81, on Flickr
50/50
DSC_0777 by SpeedFreak81, on Flickr
Working in small sections for maximum defect removal
DSC_0778 by SpeedFreak81, on Flickr
DSC_0779 by SpeedFreak81, on Flickr
Defects on door handle removed
DSC_0782 by SpeedFreak81, on Flickr
Rear door fully compounded
DSC_0783 by SpeedFreak81, on Flickr
DSC_0785 by SpeedFreak81, on Flickr
Driver's side quarter 50/50
DSC_0787 by SpeedFreak81, on Flickr
DSC_0788 by SpeedFreak81, on Flickr
Rear of vehicle full of RIDS and swirls!
DSC_0792 by SpeedFreak81, on Flickr
DSC_0793 by SpeedFreak81, on Flickr
DSC_0795 by SpeedFreak81, on Flickr
Not the greatest shots on the passenger side bc of the incoming light, but you get the idea
Passenger side quarter before
DSC_0800 by SpeedFreak81, on Flickr
50/50
DSC_0804 by SpeedFreak81, on Flickr
Passenger rear door 50/50
DSC_0807 by SpeedFreak81, on Flickr
DSC_0806 by SpeedFreak81, on Flickr
After correction
DSC_0809 by SpeedFreak81, on Flickr
Front door 50/50s
DSC_0813 by SpeedFreak81, on Flickr
DSC_0816 by SpeedFreak81, on Flickr
DSC_0812 by SpeedFreak81, on Flickr
Door fully corrected
DSC_0817 by SpeedFreak81, on Flickr
Few shots showing the new found gloss
DSC_0818 by SpeedFreak81, on Flickr
DSC_0819 by SpeedFreak81, on Flickr
DSC_0820 by SpeedFreak81, on Flickr
DSC_0822 by SpeedFreak81, on Flickr
DSC_0823 by SpeedFreak81, on Flickr
After the compounding and polishing stages were complete, the car was pulled out to be washed, and wiped down with alcohol as prep for the Opti Coat application.
Opti Coat flashing onto the paint surface
DSC_0825 by SpeedFreak81, on Flickr
DSC_0826 by SpeedFreak81, on Flickr
DSC_0827 by SpeedFreak81, on Flickr
AFTERS!!!
DSC_0829 by SpeedFreak81, on Flickr
DSC_0830 by SpeedFreak81, on Flickr
DSC_0831 by SpeedFreak81, on Flickr
DSC_0832 by SpeedFreak81, on Flickr
DSC_0833 by SpeedFreak81, on Flickr
DSC_0850 by SpeedFreak81, on Flickr
DSC_0849 by SpeedFreak81, on Flickr
DSC_0855 by SpeedFreak81, on Flickr
DSC_0856 by SpeedFreak81, on Flickr
DSC_0854 by SpeedFreak81, on Flickr
DSC_0858 by SpeedFreak81, on Flickr
DSC_0836 by SpeedFreak81, on Flickr
DSC_0852 by SpeedFreak81, on Flickr
DSC_0834 by SpeedFreak81, on Flickr
DSC_0841 by SpeedFreak81, on Flickr
DSC_0839 by SpeedFreak81, on Flickr
DSC_0847 by SpeedFreak81, on Flickr
DSC_0842 by SpeedFreak81, on Flickr
DSC_0844 by SpeedFreak81, on Flickr
DSC_0845 by SpeedFreak81, on Flickr
DSC_0867 by SpeedFreak81, on Flickr
DSC_0866 by SpeedFreak81, on Flickr
DSC_0865 by SpeedFreak81, on Flickr
DSC_0862 by SpeedFreak81, on Flickr
DSC_0861 by SpeedFreak81, on Flickr
DSC_0859 by SpeedFreak81, on Flickr
Thanks for looking and hope you enjoyed the post!
-Brian
SpeedFreak81 is offline   Reply With Quote
Old 21st August 2012, 20:16   #2
DyreM5
DyreM5's Avatar
Garage: M5 Black Sapphire Metallic
Amazing!!!! That settles it I'm trying Optimum Opti Coat. I usually go with Meguiars #21 Synthetic Sealant 2.0 and/or Swissvax Blau-Weiss wax. How hard is Opti Coat to work with?
- Dinan Stage 2 Suspension
- Dinan High Flow Air Mass Meter / Intake
- Dinan Stage 3 Engine Software
- Dinan Exhaust
DyreM5 is offline   Reply With Quote
Old 4th September 2012, 18:20   #3
Peterjk4
Peterjk4's Avatar
Garage: 1992 E34 M5 Apline White
Great work, Stunning results! Also I am just down the street from you and will be dropping by once my E34 is up and running.
Peter
1992 APLINE WHITE M5 73k BK06359
STAGE "0"
Peterjk4 is offline   Reply With Quote
Old 4th September 2012, 19:00   #4
cleoent
cleoent's Avatar
Garage: Black E60 M5
those results are incredible! I know opti-coat says it is permanent, but have you found that to really be the case?
I've asked you this before, but do you know anyone on the west coast that can detail like you can? I would love this to be done to mine.
cleoent is offline   Reply With Quote
Old 5th September 2012, 19:08   #5
SpeedFreak81
You won't be disappointed! Shoot me a PM and I can try to help out with the Opti Coat questions.
Old 5th September 2012, 19:10   #6
SpeedFreak81
As far as longevity, I generally expect 3-5 years worth of protection depending on the environment the car lives in.
Old 17th September 2012, 06:08   #7
thiknek
thiknek's Avatar
Garage: E60 M5 Interlagos Blue
Great job!!!!! Looks awsome! Just a few questions...... How Long does a job like that take.? How much does it cost.? And.... Where in NYC and surrounding area could I get that done! I have the exact same ///M
thiknek is offline   Reply With Quote
Old 17th September 2012, 20:36   #8
thiknek
thiknek's Avatar
Cant PM Yet!.... that would be great.. thanks in advance
Old 18th September 2012, 00:00   #9
SpeedFreak81
Email me your contact info. brlewis81@gmail.com
Brian
703-945-0629
Old 18th September 2012, 00:17   #10
Nerwyll@TrinityAutosport
Company representative for Trinity Autosport
Garage: e92 2011 M3 Jet Black
great work =)
Trinity Autosport
email me: nerwyll@trinityautosport.com
Nerwyll@TrinityAutosport is offline   Reply With Quote
HTML code is Off
SpeedFreak Detailed: LeMans Blue 335i + Opti Coat SpeedFreak81 Detailing Forum 10 16th October 2012 00:08
SpeedFreak Detailed: "Shopper1590"s 16k mile Interlagos Blue M5 resurrection! SpeedFreak81 USA Northeast Forum 6 5th September 2012 19:05
SpeedFreak Detailed: LeMans Blue 335i + Opti Coat SpeedFreak81 USA Northeast Forum 0 9th May 2012 02:35
AC Schnitzer ACS6 (and steel rear silencer system "Sports Trim") Interlagos Blue Dredd E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 4 9th May 2007 20:12
Is the 1K mile break in period "mandatory" or "suggested"? wolfturbo E60 M5 and E61 M5 Touring Discussion 11 8th January 2006 22:58
