Washing my BMW M: What do I need? - BMW M5 Forum and M6 Forums
Go Back   BMW M5 Forum and M6 Forums > General Forums > Detailing Forum
Like Tree1Likes
Old 22nd January 2010, 12:52   #1
Tiauguinho
Tiauguinho's Avatar
Garage: 2001 M5 Le Mans Blue
Gents,
Many times I get asked what people should buy to start washing their car in the safest and most effective way.
Below you will find mix of products that you can buy to make your own Washing Kit. This is a suggestion of the products that you should consider in purchasing, so you can start taking care of your M car in the way it deserves
2x Buckets
2x Wash Mitts
1x Shampoo
Many Microfibres
1x Window Cleaner
1x Wheel Cleaner
1x Tire Gloss
1x Brush
1x Wheel Brush (insides)
Two Buckets, what for?
Bucket Wash is used for warm water with the shampoo mix.
Bucket Rinse is used to rinse your mitt from the dirt it catches.
I think that Dodo came up with a nice Bucket set, with Grit Guards and stickers on them so you can easily identify which is which, this would be what I would buy if I would be in the market for new buckets: The Wash Bucket and The Rinse Bucket.
I bought my two buckets quite some time ago, from a webstore that doesnt even exist anymore. It is a nice set with lids that are able to retain the water inside the bucket, plus I bought some grit guards for them and they are perfect. However, I did some search and found them being sold by some other company in the USA, in case someone is interested: Gamma Seal Lid + Buckets
If you want to go full Pro and money is no question, then you have this option: Sonüs Bucket
What Wash mitts should I get?
I genuinely believe that you should always wash your car with two mitts, one for the top of the car (lambswool) and one for the bottom part which is always the most dirty, which I use for under the trim line on my E39 M5.
Currently, since I am a bit insane, I own a pet Wookie, which I love dearly for its ability to hold water and to get the dirt in the fibres, away from the paint. However, this mitt requires regular maintenance and may not be to the regular owner
Most good quality Lambswool Mitts, like the Sonüs or a Merino Wool Mitt, will be perfect for your washing.
For the bottom part of the car, you can use a normal Lambswool mitt as the above or a normal Microfibre wash mitt.
Shampoo: Lubricity, suds andcleaning power while being gentle to the Wax layer.
There are many choices here... I have tried many shampoos, too many to list.
My favorite choice is the Dodo Juice Born to Be Mild. Does ticks all the boxes for me and performs better (In my honest opinion!) then their more expensive Supernatural Shampoo.
You will also find good quality in the Zaino Z7, Meguiars Shampoo Plus or Duragloss
Just be sure to always have the correct ratio of luke warm water and shampoo!
Microfibres, soft and plushy!
These will be important tools, to help you dry, clean, polish and buff.
For Drying: Dodo Supernatural, Miracle Dryer, Sonüs Waffle Weave, PB Luxury Drying Towel and many others.
For Polish:
Good for the exhaust tips and other areas, a short nap MF towel will be perfect, since they provide more bite to really work with the polish: Sonüs Der Wunder or Marvel Polishing Towel
For Buffing: Dodo Fantastic Fur, Eurow Shag, Sonüs Der Wunder
Wheels
Preferably, your wheels are sealed and you don't need to use aggressive products regularly to clean them. If they are sealed, then normal shampoo will do fine
However, if you need a Specific cleaning product, you will find: Dodo Juice Mellow Yellow, Bilberry, Autosmart Smartwheels, etc. Please consider in sealing your wheel and in using the wheel cleaners only occasionally.
For wheel brushes, Vikan offers a great range of products that you can probably pick up from your local store. Nonetheless, when I go attack some wheels, I always have with me: Swissvax Wheel Brush, some soft Vikan Brushes and a EZ Detail Brush for the inside of the wheels.
Tires
A clean tire is a must. Always scrub your tires well with APC before applying the tire gloss, else it will just turn brownish and the products will never attach correctly.
I use the Blackfire Long Lasting Tire Gel for a wetter look and the Zaino Z16for a matte finish.
Windows
Clean windows are a constant requirement on my M5, I go crazy if they are dirty. When I travel to Portugal and do those 2200km in a row non-stop, I want my visibility to be as clear as possible and my girlfriend always helps me clean the windows while I feed the car with gasoline on the pitstops On my weekly M5 wash, all windows are cleaned, just a spray or two on the cloth will be enough (since the shampoo did most of the work already)
I use a microfibre with enough bite to get those bugs out, but still be gentle enough: Dodo Mint Merkin or its sister Supernatural.
To clean my windows I use Mark V Window Sheen but am going to order the new Brilliant Glass Cleaner very soon
Of course, all my windows are sealed on the outside with Carlack Glass Sealant. However that is going to be replaced soon with another product I'm dying to try
But Tiago... what if I want to add that little extra something after the wash or to add some more protection on top of my wax layer?
Spray Sealant is the answer, so you can add some wetness and protection to your car on top of your wax layer. Although, it won't last long (if you don't have a wax layer below you will notice it), it is still enough to hold it until you wash your car 2 weeks later (depending on mileage).
There are not many choices for a good Spray Sealant (not a regular detailing spray). I own Dodo Red Mist Tropical and Zaino Z8. There are other products on the market, but these two are what I believe to be on top of the game (Finish Kare also makes one, but haven't tried it yet).
The one I keep on using is the Dodo Red Mist, I find it easier to use, spreads better, beads better and lasts good for the milleage that I do on my car. The Z8 is a great product, but IMHO, the Red Mist just adds that little extra something for me.
Detailing can be an expensive hobby, but a fun one, with the results being all in your car. There are so many products out there that you will always have something new to try (and this is where it gets expensive). However on the above I tried to include a wide selection of products, so it can fit on the budget that each one of us has.
Coming soon... How to wash my BMW M: Techniques and Pictures
2001 BMW E39 M5 Le Mans Blue + Heritage Nappa Black Leather - Van Manen Headers, Stoptech ST-40 BBK. The Garage Queen.
2004 BMW E39 530i Touring M Package Individual Carbon Black + Cinnamon Nappa Leather. Smooth Daily Driver.
Tiauguinho is offline   Reply With Quote
The Following 17 Users Say Thank You to Tiauguinho For This Useful Post:
"S62" (15th February 2012), 5seriessport (27th January 2010), ard (10th July 2011), bmwluvr4evr (23rd January 2010), Chadderz2010 (1st August 2010), Danish (25th June 2010), FDDE39M5 (2nd March 2012), firebladegriff (3rd June 2010), Haitham (7th February 2010), Hakon (9th June 2010), Kinder (6th February 2011), Lantz (11th February 2010), Phil M5 (23rd April 2010), Pinzie (1st March 2010), Sebring NL (3rd June 2010), W1TAK (16th May 2010), yellowgixxer (10th July 2010)
Old 20th March 2010, 02:11   #2
Pinzie
Pinzie's Avatar
Garage: BMW ///M3 E30
Thx for sharing this with us!
Very interesting. Like it was last year at Frits' place ;-)
Thx Mr. T ;-)
Pinzie is offline   Reply With Quote
The Following User Says Thank You to Pinzie For This Useful Post:
Tiauguinho (20th March 2010)
Old 27th March 2010, 09:25   #3
M5 Meridian
M5 Meridian's Avatar
Garage: 2000 M5 TiSi (<30k miles)
Great little list. Thanks to your post I found Sonus and just ordered $225 worth of washing items, including that $80 bucket. I must be an idiot for paying 80 bucks for a bucket, but what got me was the padded seat. That's great for washing your wheels. Every time I get a new car I refresh my detailing stock. I almost ordered a Griot's kit, but their stuff really isn't that great.
M5 Meridian is offline   Reply With Quote
Old 27th March 2010, 09:39   #4
Tiauguinho
Tiauguinho's Avatar
Sonüs does some good stuff, I love their clay and their Microfibres
But don't grow attached to just one brand, there are a lot of companies releasing a lot of quality material!
Old 27th March 2010, 10:05   #5
M5 Meridian
Well, it's easier to order the bulk of things from just one place rather than one thing here and one there. Also, in my opinion, I can't really believe an.y real gap exists between quality products. In fact, I'm inclined to believe that a concours wax and a quality store brand car wax produce little difference I was interested in Dodo Juice's products, but their USA store is limited. Are you a professional detailer? Also, did you do a similarly detailed list on clay/wax products? I guess I could do a search to answer that. What do you recommend for "sealing" the chrome shadow wheels?
Here's my complete order:
Sonus Der Wunder SON-DWTRIO 1 49.50
Microfiber Towel Trio
Sonus Ultimate Microfiber MF-201 1 13.00
Detailing Towels, Pkg/2
Sonus Der Wunder SON-DWDT-2 1 28.95
Microfiber Drying Towels
Sonus Professional Bucket SON-PROBUCKET 1 73.00
Genuine Wool Car Wash VK-103 1 12.50
Mitt
Sonus Vision Glass & SON-150 1 8.00
Plastic Cleaner
Car and Sheepskin Wheel CR-93017 1 7.25
Cleaner
Two Way Mini Detail Brush MBM-BR-296 1 2.49
Subtotal 194.69
Shipping 19.20
Tax 0.00
Total 213.89
Old 27th March 2010, 10:08   #6
Tiauguinho
Tiauguinho's Avatar
I'm not a professional detailer, but a hobbyist
Dodo Juice has some really nice products and their customer support is very good. Have a look at their Wax line, they are good quality and very well priced!
For sealing the wheels, something like Poorboys Wheel Sealant or Collinite 476s will serve you fine!
Old 3rd June 2010, 13:11   #7
firebladegriff
firebladegriff's Avatar
Garage: BMW M5 Le Mans Blue 2002
Originally Posted by Tiauguinho View Post
Tires
Sorry for being dumb!!!
What is ATC? I am guessing automotive Tyre cleaner but would like to be sure.
Cheers Griff
PS I have just aquired my first ever Clay bar set and I am so excited! Sad or what?
firebladegriff is offline   Reply With Quote
Old 3rd June 2010, 17:02   #8
Tiauguinho
Tiauguinho's Avatar
Cheers Griff
Its not ATC, its APC: All Purpose Cleaner.
Like this one, Meguiars All Purpose Cleaner.
Old 8th June 2010, 14:26   #9
carlgrz
carlgrz's Avatar
Garage: E39 M5 Carbon Black
Ok so I have the washing part pretty much sorted. Now I am about to venture into the world of a machine polisher. There are so many different pads and products. Where do I begin? I don't want to make it over complicated to start off but I would like to get good results for the expected time outlay!
carlgrz is offline   Reply With Quote
Old 8th June 2010, 14:37   #10
Tiauguinho
Tiauguinho's Avatar
Hmmm, I will try to make a little recommendation, in terms of machine, pads and polishes for you when I get home
HTML code is Off
Washing and Waxing My M6 and Your M6 Demon_M6 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 7 5th May 2006 05:03
washing BMW EXTREME!! baldy_bonce E39 M5 and E52 Z8 Discussion 9 17th January 2005 19:35
Beast washing ? iMac E39 M5 and E52 Z8 Discussion 33 15th October 2004 17:40
Washing Mitts se E39 M5 and E52 Z8 Discussion 21 16th September 2001 19:30
Washing & detailing? M5-BEAR E39 M5 and E52 Z8 Discussion 17 23rd January 2001 16:59
