Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > BMW M5, M5 Touring, M6 and Z8 Forums > Detailing Forum
Detailing Forum Sponsored by Detailers Domain
Old 12th May 2009, 19:35   #1
doc$holliday
doc$holliday's Avatar
Garage: 2003 M5 Le Mans Blue
can't get the swirls out - advice if you please.
Hello,
I posted this to Phil in the Detailer's Domain advice sticky but thought it couldn't hurt to make a new thread in case anyone else would like to weigh in on it.
I have a 2003 M5 in LeMans Blue Metallic that has a ton of paint swirls, marks, some scratches, etc. Basically it needs a good corrective detail to get it back to a level where I can maintain it, as the paint has been like this since last January when I bought it with 100k miles on the clock.
I do have Meguire's Detailing Clay which I have used in the past on my Z3. I also have a Porter Cable dual-action random orbital with a great assortment of good pads. In terms of product, I have a Pinnacle Liquid Souveran wax but am probably falling short in the area of swirl mark removers/polishes as I only have 3M Swirl-It II SMR for dark cars and some other Mequire's finishing polish.
I have tried, unsuccessfully, to use the above items on the hood and trunk of the M5 to clean up the swirls, etc. I've done a bit of research on these boards and have looked at some of the detail pro's as they post before and after pics - and I cannot really make my paint look much better! Is it me, or the products I'm using, or a combination? As an example I would use the SMR with an orange pad on the orbital, then a white pad with polish then a black pad with Pinnacle.
Also, the high mileage is mostly highway driving and so there is a large amount of road rash, chips, etc. on the front of the hood. I was considering a Dr. Colorchip kit for the rash - thoughts?
I live in South Florida and really need to get a good coat of wax on soon as the summer (and it's sun and rain) are almost here. I have seen only about 1 pro on this board for my area. I did contact him (his photos are amazing!) and it's not out of the realm of possibility but is $$$. Do you know of any others in the Fort Lauderdale/Miami area?
Thanks in advance for reading my long post and for any advice you may have!
SP
Sean Paul
2003 M5 LeMans Blue/2-tone blue & black
doc$holliday is offline
Old 12th May 2009, 22:27   #2
6pack
6pack's Avatar
Garage: 07 M6 Black Sapphire Metallic
You may need to drop down to a more agressive polish and then go back to a fine one.
I use these from griots garage.
Set of 4 Machine Polishes - Polishes - Polishing - Car Care - Griot's Garage
I am not famliar with the grade of the polish you are using.
If all else fails, pay the big bucks to get it right and then you mintain yourself going foward. They have a nice instructional video that you can get.
2007 M6 Black Sapphire Metallic/Carbon Fibre Trim
Eisenmann Race Oval Tips
3M Clear Bra
RPI Scoops (Black)
K40 Calibre Radar w Bluetooth Remote & Defuser EX
Sprint Booster
Vorsteiner Carbon Fibre Front Spoiler
Dinan H Flow Air Mass Meter/Intake D763-0044
Dinan Cold Air Intakes D760-0021
Dinan 13% Pulley D560-0001
Dinan Stage 3 Software D903-51M3
Dinan H Flow Throttle Bodies D760-3800A
Dinan 3.91 LSD D773-0601A
Dinan CF Strut Brace D180-0007A
Dinan Stage 2 Suspension D190-6318
2007 Escalade ESV/Black Raven
All Options Available
2009 CTS-4/Black Raven
6pack is offline
Old 13th May 2009, 12:47   #3
TOGWT
Garage: M6 Blue
Its hard to tell from a description how srious the scratches are. It would seem that a SMR is not removing the scratches, which would indicate that you need to move to a more abrasive polish/pad. As a suggestion Menz Power Finish (PO203S) - (M) this is a one-step scratch remover polish that will remove 2500 grit, cut 3.0-gloss 3.5, is formulated as a quick way to polish out light flaws and amplify the paint’s gloss.
TOGWT is offline
Old 13th May 2009, 18:34   #4
Feld1128
Garage: 2000 M5 Imola Red
Since you have different type of scratches, swirls etc. take it to a body shop and have them do what is necessary. You may need to do some color sanding to get scratches out depending how deep they are, then go through the different compounds to end up with a desirable result. Have them mix some paint for touch up, keep in mind touch up will never look as good as painted. It should not cost any more than one day of labor plus a minor materials charge, to give you an idea my shop would charge about $400.00 to 500.00 dollars for this. If you want to do this yourself I can give you a list of materials and pads etc. with part #'s . Good Luck.
Feld1128 is offline
HTML code is Off
Light Swirls + Scratch's maddernj E39 M5 and E52 Z8 Discussion 19 15th April 2008 20:41
Advice on preventing paint swirls? benfmd E60 M5 and E61 M5 Touring Discussion 27 24th September 2007 23:15
Swirls and Bra bodaddy E60 M5 and E61 M5 Touring Discussion 6 28th October 2006 06:15
Fixing paint swirls milazotes E39 M5 and E52 Z8 Discussion 5 20th May 2003 18:16
Paint Swirls! MANNY E39 M5 and E52 Z8 Discussion 28 19th December 2001 05:52
Page generated in 0.10682 seconds with 11 queries
