Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > BMW M5, M5 Touring, M6 and Z8 Forums > Detailing Forum
Detailing Forum Sponsored by Detailers Domain
Old 8th July 2006, 03:01   #61
m_five
m_five's Avatar
Garage: '05 545i silver gray
Originally Posted by NeVeTaS
Why is the portrr cable safe and the machines not safe.
Whats the differance?
Does the porter just work at lower speeds or something?
The rotary buffer just spins on its axis, and if you're not careful and skilled, you'll end up burning your paint. Imagine putting a buffing pad on your power drill.
The random orbital spins in a random pattern. Though not exact, think of a drill that not only spins, but also moves its axis in a random pattern.
m_five is offline
Old 8th July 2006, 03:58   #62
Realtycar
Realtycar's Avatar
Garage: M5 E60 Black
M five...you are prob an old timer like me....times have changed....a novice can use this buffer nowadayz.
Because the puffing pads are Foam and not wool, you can't burn the paint. I will make a video to show you a buffer using a foam pad for 20 seconds in 1 spot using "3M RUBBING COMPOUND"....and you will see nothing but smooth. you Will NOT get more scratching in this system as it does NOT use gritt to "cut" the paint like in the past.
I will be honest,,the picture of the BEFORE AND AFTER I used the 3M Rubbing Compound with NO WAX on it....I did NOT USE the Swirl Remover or Final glaze after. That shows you that it doesn't make more marks! I did that because I was lazy and it's my brothers car and he was giving me crap about leaving to pick up his girl friend.
I would have said the same thing 1 year ago until I learned about this 3M line. There is NO RISK, if my brother can do it, ANYONE CAN! Foam pads absorb heat, after 20 seconds, you can put the side of your face on the paint.
Answer to some questions.....
You would have to buff your car 30 times using "rubbing compound" before you would have to worry about anything
Or
50 times using the 3M swirl remover. Rubbing Compound is more agressive than the swirl remover.
You would have to break down the "ORANGE PEEL" before you would start to lose your coats! I have done my fathers car 1 car for 10 years, did it every 6 months. thats 20 times on an old 300zx with swirl remover.
Anyone can do this with a high speed buffer and NOT WORRY! Try it on the back quarter pannel or the wifes/kids car on a spot if your nervous, then you will see, there's nothing to be nervous about.
It does not REMOVE like in the old days...it sort of blends/smooths out scratches, hard to explain....thats why they have PHD's working at 3M...
If people would find out how easy and safe this is, body shops would not be happy!
The first 2 cars I did I was nervous about using the Rubbing Compound if fear that it was too agressive and now...I possitive that it is Safe!..let alone using the Swirl Remover....that I would use on my "first childs" butt! it's THAT SAFE!
RUBBING COMPOUND http://repaintsupply.com/pd_perfectit_iii.cfm
SWIRL REMOVER...............http://repaintsupply.com/pd_perfectit_3000_swirl.cfm
FINISHING GLAZE SITE>.....http://repaintsupply.com/pd_perfectit_iii_finishing.cfm
Realtycar is offline
Old 8th July 2006, 04:23   #63
m_five
m_five's Avatar
You would have to buff your car 20 times using "rubbing compound" before you would have to worry about getting anothe layer put on.
Or
40 times using the 3M swirl remover. Rubbing Compound is more agressive than the swirl remover.
Well...I suppose I am an old timer. I certainly understand the technology of pads and polishing products has changed, but I'd still caution the novice about using a rotary buffer. Just my opinion.
In one of your posts, you even talk about the speed and heat of the rotary buffer.
Your problem is that you used a "random orbital" buffer...like I SAID!!! that is only good for putting on wax! That Porter Cable crap is for the man of the home to save time putting on wax. The HIGH SPEED professional buffer cuts way faster.....for 89 bucks more than Porter Cable, you could have saved 4 hours! get a man's buffer....you will use it for the rest of your life! Well worth the money..it's all about the RPM and heat! The Swirl remover has NO GRIT...it cuts by heat...and you can't get it hot enough with out 1400 rpms....the 3M guys will tell you that.
m_five is offline
Old 8th July 2006, 06:06   #64
Realtycar
Realtycar's Avatar
warm enough to melt butter over 2 min but not enought to burn the paint. That's about it....I will make a video this week for everyone and show the pad on the same spot for 15 seconds...or so...it is truly amazing. The old school of doing it with the "wool" pads, you wouldn's even stop in 1 spot for 2 seconds...let alone "sit and spin" in one spot for 15.
Old 11th July 2006, 17:27   #65
Realtycar
Realtycar's Avatar
I will start a new post with a video...I am going to try to keep the camera on the surface so you see the magic happen as it "gets" polished. Also I WILL do the on paint for 15 seconds @1400 rpm to prove using Foam Pads and 3M is safe for all to do. You won't burn the paint!
Old 11th July 2006, 19:11   #66
MEnthusiast
MEnthusiast's Avatar
Garage: 03 M5
I am looking forward to learning a new technique!
All the best,
MEnthusiast is offline
Old 11th July 2006, 19:17   #67
1000 Oaks
1000 Oaks's Avatar
Garage: 2006 M5 Met Blk
Thanks for posting a source where we can buy the 3M products. I got anxious before you posted and bought directly from 3M. Although, I think the products are slightly different. I was planning on hand application with a soft white cloth? Am I crazy, should I go and buy the DeWalt Buffer? what do you think?
1000 Oaks is offline
Old 11th July 2006, 19:41   #68
///Marshall
///Marshall's Avatar
Garage: BMW M6 Sapphire Black
Realitycar, any good suggestions on removing tree sap? Somehow
I got a huge splat on my hood. Must have been just driving under
a tree as I always park in a garage. I tried removing it with clay
but it ended up creating a nasty blemish in my Sapphire Black!
///Marshall is offline
Old 11th July 2006, 22:31   #69
WLightning
Garage: Black/Black M5
Ya didn't ask me, but...
3M has a good product called Adhesive remover (or somethin like that) - any autobody shop will have it for removing the goop from stickon letters.
A microfiber towel and some of that thin liquid should do it. DO NOTE, you'll strip your car down to the paint so it'll need wax or something in that area.
WL
PS - I think its this stuff... http://www.sherwin-automotive.com/pr...?product=39800 or maybe this is the new stuff? http://products3.3m.com/catalog/us/e...er/output_html
WLightning is offline
Old 11th July 2006, 22:43   #70
Habib_2
Habib_2's Avatar
Garage: Prius
I'm not RealityCar but I use ethanol (almost 100% alcohol) on a piece of soft cloth to remove the tree resin.
Habib_2 is offline
HTML code is Off
Should I use a swirl remover? benfmd E60 M5 and E61 M5 Touring Discussion 1 31st May 2008 10:32
3M Swirl Mark Remover for Dark Colored Cars tbalon E39 M5 and E52 Z8 Discussion 12 31st August 2007 06:38
3M Swirl remover and P21s..on Black Realtycar E60 M5 and E61 M5 Touring Discussion 122 23rd April 2007 22:08
Zaino vs 3m+P21s...Pictures Realtycar E60 M5 and E61 M5 Touring Discussion 23 6th July 2006 03:49
Swirl Remover - the ultimate answer? MAH E39 M5 and E52 Z8 Discussion 18 28th September 2004 02:44
Page generated in 0.14380 seconds with 12 queries
