Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > BMW M5, M5 Touring, M6 and Z8 Forums > Detailing Forum
Detailing Forum Sponsored by Detailers Domain
Old 27th June 2007, 06:48   #1
FAST 5
FAST 5's Avatar
what's the best way to clean engine bay ?
Guys, After being at the autobody shop for 6 months, my car's engine bay is very dusty and to my eyes its filthy! I've never cleaned an expensive car's engine bay before. I did this back when i was a teen, using a garden hose and a can of GUNK spray can product, but i wouldn't dare do this to an expensive and modern engine as the M5 motor, especially since there is a blower there, and i don't want to cause any possible water damage. What is the safest and best way to clean our engine bay and not dry out any rubber hoses or similar parts ?
thank you for your reply.
FAST 5 is offline
Old 27th June 2007, 06:56   #2
EM5PWR
EM5PWR's Avatar
Garage: 02 M5
I've hear the 'scrubbing bubbles' work good. Haven't tried it yet but a friend says it works great.. Spray on , wait a few, then hose off..
EM5PWR is offline
Old 27th June 2007, 07:04   #3
nota_troll
Garage: JetBlackM5
I was just looking to do this as well. Most of my detailing knowledge and products starts at properautocare.com. Today I ordered some swirl remover products but I'm not brave enough to spray a hose onto this motor.
http://www.properautocare.com/prencl.html
Seems easy enough...maybe later.
nota_troll is offline
Old 27th June 2007, 07:09   #4
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
i've rinsed my engine compartment down plenty of times. Used the hose, not a ton of pressure or volume. Take it for a nice drive after to dry out everything. The stuff is pretty waterproof. I have some zep degreaser that i dilute down quite a bit, spray and hose it down. Have used a pressure washer from below, but the garden hose is plenty usually.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 27th June 2007, 07:48   #5
TQ2K
TQ2K's Avatar
Garage: 2003 BMW M5 - Petrol Mica/Champagne
Sales Feedback: (6)
Send a message via MSN to TQ2K Send a message via Yahoo to TQ2K
Robert,
Take it to Phil @ Detailers Domain and he'll take care of your car. He's in NJ as well so shouldn't be tough to get to his place.
http://www.detailersdomain.com/index...TION=CONTACTUS
TQ2K - |
'03 BMW M5 - Individual Petrol Mica/Champagne
- UUC Evo III SSK, DSSR, & Clutch Stop
- OEM Bluetooth + Snap-in Adapter | OEM Backup Camera
- SS Headers, X-Pipe, Exhaust | Dinan CAI + HFM + IATS
- Dinan S2 (Koni) & Rear Strut Brace | Strong Strut Brace
- Brake Ducts | 19" BBS CH Wheels | TCD Brackets
- Custom PC Gold 93v3 | Dinan Lightened Dual-Mass Flywheel
- Voltphreaks VPH 900 (7lbs. Lightweight Race Battery)
'04 BMW X5 4.4i - Alpine White/Truffle
TQ2K is offline
Old 27th June 2007, 07:54   #6
FAST 5
FAST 5's Avatar
TQ2K.............
Thanks a lot. i will look into this place. What do you know about them ? Anything at all ???
Thank you.
Robert
FAST 5 is offline
Old 27th June 2007, 09:24   #7
Olyar15
Garage: 2003 Carbon Black M5
I've washed engines on all my cars and so far, have not had a problem. I like using p21s Total Auto Wash, which is a citrus cleaner. This product has a million uses, and does a good job with the engine bay as long as it isn't heavily caked with grease. For those situations, WD-40 and a lot of elbow grease works well, followed by p21s TAW to remove the residues. Using a garden hose is fine. I wouldn't use a pressure washer or anything like it. Dry with a microfiber cloth or use an air compressor. Follow with something like 303 protectant on the rubber and plastic bits.
One more hint: be careful wiping the plenum. Its texture will cause it to collect lint, even from microfiber towels. Best bet is to dab the plenum dry, or use an air compressor or blower to dry it.
Charles
Carbon Black/Champagne Individual interior '03 M5 - Tubi exhaust, SS headers, CNS Racing clutch, Fikse FM/5 18" wheels, Bluetooth retrofit.
'09 Honda Fit "dogmobile"/daily driver
'04 supercharged Acura NSX, 385RWHP
Olyar15 is offline
Old 27th June 2007, 10:02   #8
Racerxjling
Racerxjling's Avatar
Garage: 03 M5 Silver/black/blue
Sales Feedback: (12)
I've used $2 can engine degreasers for years on all my cars w/o issue. You pretty much use the entire can for each job. Do it before washing the car as the fenders will be wet and you will want to wash off any cleaner. Spray the degreaser on a cold engine...let sit for 5 minutes max. Use a regular garden hose on "spray" not "jet". Rinse from highest point of engine bay to lowest thoroughly. Rinse it off the paint if you got some on the fenders. Drive the car around 15 minutes right away. Let the engine cool. Spray regular Armor All on the rubber hoses and plastic pieces incl. air intake covers. Drive the car another 15 minutes (it will stink a bit but will dissipate with every drive). Engine bay will look brand spankin' new. Don't forget to wash the car!!
Jeff
Supersprint headers, AA CAI, Velocity Stacks, D/A Software, Evosport Pulleys, SSR GT3 19" Wheels, AC Schnitzer Pedals/E-brake/Shift Knob, Euro Headlights, HID Fogs
Racerxjling is offline
Old 27th June 2007, 10:21   #9
Ocean's M5
Ocean's M5's Avatar
Garage: 2002 M5
Note: Make sure you wash engine bay when car is cool or cold. That way you can temporarilly place a plastic bag over the alternator without the bag melting. Make sure you wrap it up so water doesn't drip in when removing the bag.
Story:
No power in my car except the battery afternew alternator was installed?
Well my gf washed the engine with water and the alternator got shorted i suppose...got a refurbish alternator from honda..car ran good for few days...but when battery run out...the alternator dont charge battery or even work..car just lost power on me in the street and now wont go on unless a new battery is put on....WHT ELSE CAN BE THE PROBLEM..ALTERNATOR DEFEC??...OR WIRES THAT WAS ALSO SHORTED FROM WATER
I'm sure there must be other places where water shouldn't be...?
2002-05 Build Carbon Black ///M5
First Aid Kit ~ Warning Triangle ~ Full BMW Tool Kit
Rear Cupholders ~ Stubby Air Stems ~ Rear Shades ~ PDC
M Audio ~ Fold-Down Rears ~ Black Sport Int.~ Yokohama Advan Sport~
Beast Power Sway Brackets ~ Tinting-80% Strip Windshield
Center Armrest *Storage Bin ~ ///M Black Trunk Mat
Ocean's M5 is offline
Old 27th June 2007, 12:44   #10
mohan
Garage: e39 M5, silverstone blue
use baby wipes... they shift all the gunk, can be used on the plenum cover and leave the hoses looking like new, esp if they are moisturising wipes.
'99 E39 ///M5 (ex-mistress, sorely missed)
mohan is offline
HTML code is Off
what's the best way to clean engine bay ? FAST 5 E39 M5 and E52 Z8 Discussion 104 28th October 2007 20:10
How to clean the engine compartment? AUH M5 E60 M5 and E61 M5 Touring Discussion 11 25th March 2007 23:04
My clean engine... Kin Mak E39 M5 and E52 Z8 Discussion 4 3rd July 2005 12:34
Clean engine compartmen? Bulletprof E39 M5 and E52 Z8 Discussion 3 2nd January 2005 21:02
Steam clean the engine bay? ALX E39 M5 and E52 Z8 Discussion 15 7th September 2001 23:46
Page generated in 0.15372 seconds with 12 queries
