Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > BMW M5, M5 Touring, M6 and Z8 Forums > Detailing Forum
Detailing Forum Sponsored by Detailers Domain
Old 29th June 2007, 09:06   #41
Envisage0
Garage: E39 M5 Avus Blue
Originally Posted by Hawkwind View Post
I don't have a clue what you're talking about.
Clearly
**** it, let's do it - Australian proverb
Envisage0 is offline
Old 29th June 2007, 09:14   #42
ard
ard's Avatar
Envisage-
What exactly seems to be your problem?
Perhaps you should go back and re-read the posts from the beginning and loose the attitude.
ard is offline
Old 29th June 2007, 09:28   #43
Envisage0
Originally Posted by ard View Post
Envisage-
Attitude? I don't think so. Subject closed.
Old 29th June 2007, 14:30   #44
Sebring NL
Sebring NL's Avatar
I was not aware that the M5 engine compartment was hermetically sealed to all water.
The warnings about rinsing off the engine bay simply must be due to the fact that once the hood is closed no water can enter the compartment when driven at 90MPHG through 1" per hour rain storms....
Yeah, being a wiseask, but I'm just not getting it. How can it be OK to drive yet not OK to rinse? Does it really stay dry?
I'm not saying it will always fail when using water.
It is ok to rinse it in some places.
I just wouldn't take too many risks.
If your car develops a warning light or short circuit of some kind, what will you say? Wout was right? That won't solve the problem.
If you need more convincing, maybe you should try watering down your engine bay
///M5HD91-229-
|Eibach|Koni|Porsche Brembo
for looking through the windscreen
///M535iDC71-181-
|H&R|Bilstein|Sparco
for looking through the Lexan side windows
B6 3.5 1531-668-
|Dogleg|Glanzschwarz
for fun
C1 2.5 1531-184-
|D-1 cage|full race spec
for looking at chequered flags
740d GE81-317-
twinscroll v8 diesel daily
Sebring NL is offline
Old 29th June 2007, 17:06   #45
Ocean's M5
Ocean's M5's Avatar
Garage: 2002 M5
Engine bay cleaned. I actually used Fantastic, and a pressure washer... Ok I'm wearing Flame ******ent Clothes.
I did cover ballasts, and alternator, and was careful where i sprayed. First I guess I should let you know that I had a small leak that ran down from the lower power steering pump hose, which with dust, made a thick, black, oily coating over the mesh that covers the Power steering hose.
I put car up on Rhino Ramps and removed under coverings. Noticed oil on the bottom of Power steering pump, and a more than a few drips of oil from a sensor located on the passenger side, lower portion of the oil pan.
So i sprayed the entire underside of engine and break area being careful not to put direct pressure on any rubber or Elec connections.
After looking like i went for a swim, I dryed engine with towel, removed plastic bags and allowed to dry in the sun for about an hour.
Started up and all seemed fine.
2002-05 Build Carbon Black ///M5
First Aid Kit ~ Warning Triangle ~ Full BMW Tool Kit
Rear Cupholders ~ Stubby Air Stems ~ Rear Shades ~ PDC
M Audio ~ Fold-Down Rears ~ Black Sport Int.~ Yokohama Advan Sport~
Beast Power Sway Brackets ~ Tinting-80% Strip Windshield
Center Armrest *Storage Bin ~ ///M Black Trunk Mat
Ocean's M5 is offline
Old 29th June 2007, 18:59   #46
whatheheck
whatheheck's Avatar
Garage: 2006 M6 Indianapolis red
Sales Feedback: (3)
Looks clean to me! Thanks for sharing experiences and photo.
All we are saying here is - when cleaning your engine - PLAY IT SAFE. No need to risk a possible electrical malfunction later due to water or moisture getting inside sensitive electrical connections - that's all.
If some people here still feel that there is no need for a concern, then by all means, hose your entire engine compartment down with water and cleaning solution and hopefully - nothing goes wrong later.
All I know is - one of the most difficult issue to troubleshoot is intermittent electrical connection. It will drive you nuts as it is hard to duplicate the issue. INTERMITTENT.
I also do know, here in aerospace business, we design our connectors to be mounted sideways to further protect the connectors from moisture or liquid going directly into electrical connections.
Our electrical harnesses are routed with "drip loops" to divert liquid or moisture away from connections.
Lots of good design practices we put in place to protect the flying public.
At any rate, the inputs I provided and so as some folks here did too are precautions to take to avoid possible trouble later. If some owners still feel there is no need to worry about it, then by all means, do as you wish.
Dan
Supersprint Headers, Tubi Rumore Plus exhaust, Dinan CAI, Defi Heads Up Display, Strong Strut front anti-sway bar, Powerchip 93 S/W, Euro Arm rest, Fikse Profil 5S Rims; Goodyear Eagle F1 GS-D3, Polk Audio Tweeters, Boston Acoustic Speakers, Integrated 60gig Video Ipod, HiDef DICE Radio iPod interface, Icelink, Rouge Engineering Short shifter, StopTech Big Brake Kit, TC Design rear sway bar brackets, HID 8000k fog lamps, 8000K low beams, Euro clear corner HID headlamps, Mark IV Nav, Lamin X films, Predator ICE LED AE, Valentine 1, M20 Blinder Anti Laser, TEC cup holder, All LED interior lights, LED footwell lights, LED trunk lights, Ultimate Cup Holders, Hella TC-400 Tire Pressure Monitor System, etc.
whatheheck is offline
Old 29th June 2007, 20:48   #47
ks7827
Garage: 2002 M5 TiSi
Dan - For us newbies, how about posting a picture of which parts of the engine bay we need to cover before we hose it down? Thanks.
I vote for this thread to be in the FAQ.
ks7827 is offline
Old 29th June 2007, 22:41   #48
Hawkwind
Hawkwind's Avatar
Garage: 2003 M5 Sterling Gray
Clean smell?
With a clean engine, do you notice any odor after you've parked in the garage with the engine hot? I had a PS hose leak that is now fixed (I think), and it seems that the residue would have burned off after a couple thousand miles, but maybe it lingers forever. Wondering whether a good engine cleaning would do much good, or if there's always the smell of oil/fluid when the engine is hot.
Hawkwind is offline
Old 29th June 2007, 23:22   #49
whatheheck
whatheheck's Avatar
Sales Feedback: (3)
Again, I do not recommend petroleum based engine cleaner such as Gunk. Your engine will smell for months.
Use Scrubbing Bubbles. So easy to use, spray on, hose off. Odor is much much reduced, the smell burns off in about a day.
I used to use Gunk and my engine would smell for weeks.
Dan
Old 29th June 2007, 23:28   #50
gmakishima
Garage: 2002 M5 (E39) Sterling Gray
Hi All,
I read someplace that aluminum foil can serve as a good cover for electrical components when you wash your engine. It adheres and molds to the thing you're trying to protect and won't melt like plastic (though I don't think it's wise to wash an engine that's hot anyways). I've never tried this method, and I still don't think you should apply too much water pressure even though the electricals are covered. Also, I wonder if this may cause more problems if water does get in since the foil can act as a conductor?
Gordon
gmakishima is offline
HTML code is Off
what's the best way to clean engine bay ? FAST 5 E39 M5 and E52 Z8 Discussion 104 28th October 2007 20:10
How to clean the engine compartment? AUH M5 E60 M5 and E61 M5 Touring Discussion 11 25th March 2007 23:04
My clean engine... Kin Mak E39 M5 and E52 Z8 Discussion 4 3rd July 2005 12:34
Clean engine compartmen? Bulletprof E39 M5 and E52 Z8 Discussion 3 2nd January 2005 21:02
Steam clean the engine bay? ALX E39 M5 and E52 Z8 Discussion 15 7th September 2001 23:46
Page generated in 0.15265 seconds with 12 queries
