Come on, admit it - you're the western region distributor for Scrubbing Bubbles!
Dan
Supersprint Headers, Tubi Rumore Plus exhaust, Dinan CAI, Defi Heads Up Display, Strong Strut front anti-sway bar, Powerchip 93 S/W, Euro Arm rest, Fikse Profil 5S Rims; Goodyear Eagle F1 GS-D3, Polk Audio Tweeters, Boston Acoustic Speakers, Integrated 60gig Video Ipod, HiDef DICE Radio iPod interface, Icelink, Rouge Engineering Short shifter, StopTech Big Brake Kit, TC Design rear sway bar brackets, HID 8000k fog lamps, 8000K low beams, Euro clear corner HID headlamps, Mark IV Nav, Lamin X films, Predator ICE LED AE, Valentine 1, M20 Blinder Anti Laser, TEC cup holder, All LED interior lights, LED footwell lights, LED trunk lights, Ultimate Cup Holders, Hella TC-400 Tire Pressure Monitor System, etc.
My HID ballasts quit working after I got it accidentally wet while cleaning my engine. Removed and replaced.
One of my stock HID bulbs burned out after I got that one wet too while cleaning my engine. Removed and replaced.
Lessons learned stuff for me worth sharing.
We can do a search here, some of the most challenging problems to diagnose were traced to moisture on the connectors thus creating an intermittent connection.
So, mine is only a recommendation and sharing my personal experience, and based on posts I've read here, I would play it safe and protect the connectors.
Here in Aerospace world, we use moisture proof / environmentally sealed connectors. I dont think that's the case in most cars, even BMW.
Originally Posted by jjc1843
Even with all the connections getting wet, evaporation would take care of it pretty quick--a day or so if the car isn't able to run. Repeated soakings may cause corrosion.
They have an intermittent connection somewhere. The gauges are so heavily damped (meaning slow to respond) that instant hits full or to zero always means electrical problem.
An alternator cannot be damaged by basic water; not spray from a hose, and not permanently unless you decide to gatorade congratulate your alternator.
Dan
Pure water by itself is not a conductor of electricity. All the chemicals and impurities that are held in suspension are what conduct electricity. All you swimming pool owners already know this. I would not worry about shorting out any connections, unless they stay wet long enough to corrode. That would take a few weeks to occur.
I am a professional detailer and this is how I do mine.
I do it with the engine warm. Warm compartments clean and degrease better I find. You do need to be selective as to where you spray things although I have never needed to cover an alternator once. I actually do this with the motor running so that if water by chance is getting into somewhere where it shouldn't be, you'll hear it.
Sorry, but this is BS.
I was a pro detailer for years and we ALWAYS put bags over the alternators. Even on old Mercedes diesels, I would not recommend this method.
If water gets somewhere it shouldn't get you'll hear it?? Yeah, but its a bit too late then! Also, with a hot engine, water is about the worst thing you can use, as it leaves stains immediately. Using degreaser or the diluted whatever, and chances are big that the hot metal will sustain ugly spots you will not get off without a serious compound polish. Also, things like ignition leads etc will become brittle when putting cold water on them in hot state.
Sorry man, but I just can't have other board members try this. Seen too much stuff go wrong for letting this pass. Consider yourself lucky untill now, the amount of warning lights coming etc on cars that I have seen washed with water is endless...
Toothbrush and a can of degreaser for hard to reach places..You might wanna use a bit of auto-disappear wax ( yes, wax that disappears after use, no need for wiping off) to get things like cosmoline drips off.
__________________ ///M5HD91-229- |Eibach|Koni|Porsche Brembo for looking through the windscreen ///M535iDC71-181-
|H&R|Bilstein|Sparco for looking through the Lexan side windows
B6 3.5 1531-668-
|Dogleg|Glanzschwarz for fun C1 2.5 1531-184-
|D-1 cage|full race spec for looking at chequered flags
My results with a pail of water and liquid car soap and lots rags. Only wet the rags and then squeezed out most of the excess...This was after a winters (4 months) worth of driving...not great, but not bad either.
Dinan CAI
Steel Braided Brake Lines
Mark III Computer
I was not aware that the M5 engine compartment was hermetically sealed to all water.
The warnings about rinsing off the engine bay simply must be due to the fact that once the hood is closed no water can enter the compartment when driven at 90MPHG through 1" per hour rain storms....
Yeah, being a wiseask, but I'm just not getting it. How can it be OK to drive yet not OK to rinse? Does it really stay dry?
I never have a big issue with the engine area being dirty, I generally wipe it down with a damp towel then apply Adam's In & Out spray. (no, I don't sell it)
