V1 Hard Wired - BMW M5 Forum and M6 Forums
BMW 1 Series M Coupé, X5M and X6M Forum Forum for X5 M, X6 M, xDrive35i, xDrive50i and xDrive30d. Also for X5 4,8i, 3,0si, 3,0d and 3,0sd.
post #1 of 6 Old 21st July 2014, 03:06 AM Thread Starter
WallyM5
WallyM5's Avatar
V1 Hard Wired
This is a quick job, takes about 15 minutes:
1. Remove the light assembly by the rear mirror by pulling down from the mirror area first. There is a hinge at the rear of the assembly, that is why you will need to start at the front. Just pull on it, there are a few metal clips.
2. At the rear of the assembly you will see 4 or 5 wire harness and alot of wires!! You will tap in the the GREEN/white wire on the second to last plug on the passenger side. There are a few large 20 wire harness and a couple small 4-5 wire harness. Mine was black.
3. Plug back the tape to make some room and clip on to that wire.
4. For the ground I just drilled a small hole in the metal frame where there was a flange and screwed in a small bolt to ground the unit.
5. I ran the cord out the top of the head liner. It just pushes throw....it was too easy.
Test to make sure it's on and off with power and you are SAFE again!!
"An on ramp is a terrible thing to waste"
X5M
V1 Hardwired
Charcoal Filter Delete
K&N
Exhaust Cutouts
WallyM5 is offline
post #2 of 6 Old 19th September 2014, 11:29 PM
alpina527
alpina527 is offline
post #3 of 6 Old 5th November 2014, 12:30 AM
2modfast
2modfast is offline
post #4 of 6 Old 8th September 2015, 12:11 AM
m5james
m5james's Avatar
Nice, now I just need to decide between the ValentineOne vs the Escort. Can these be wired into the dash like prior BMW's or is that why you kept it simply by mounting it there?
325hp '98 BMW 740iL, black on black - Eatin 540's and $hittin 318's
6spd, iron sleeves, L/W Teflon coated & silicone impregnated pistons, 3 angle valvejob, P&P head, perf cams, electric fan, CF intake tube w/aluminium heatshield/wrapped MAF tubing, Magnaflow 94006/14816 w/ notched bumper, Bilstein/H&R Stage II/Powerflex
282hp '01 X5 4.4, white on black
F90BT, JH300/L5 8", LED AE
340hp '91 ///M5 #MBK05613, black on gray
CVA1005, D'Sylva chip, UUC SS
115hp '01 Suzuki TL1000R, blue and white - Duc eater
M4 full exhaust, K&N filter, Yosh reprogram, gutted airbox, TRE, Pilot Race tires
m5james is offline
post #5 of 6 Old 16th June 2016, 06:42 PM
04yfz
That spot is the best for radar detection with any detector, you want it as high as possible. The v1 has a remote display you can attach to allow you to mount it anywhere, I believe the older ones had it in the dash through special modules available aftermarket. They stopped producing them and I haven't seen anything similar for the newer cars.
04yfz is offline
post #6 of 6 Old 17th June 2016, 02:40 AM
m5james
m5james's Avatar
I've reused my old detector I've had since high school and then couple it with using the Waze app.
m5james is offline
DIY: Can someone tell me what my car is wired for? ///m62e39 E39 M5 and E52 Z8 Discussion 4 13th April 2013 08:10 PM
adjustable headlamps pre-wired? WMWNWMN E34 M5 Discussion 9 30th December 2006 12:09 AM
AR's M5 in Wired Mag bonehead Gumball 3000 Forum 8 18th November 2006 11:38 PM
Wired ECB E39 M5 and E52 Z8 Discussion 0 15th January 2006 09:40 PM
Hard-Wired V1 Acting Up Tom M E39 M5 and E52 Z8 Discussion 8 3rd March 2003 05:14 PM
