Carbon Filter Delete - BMW M5 Forum and M6 Forums
BMW 1 Series M Coupé, X5M and X6M Forum Forum for X5 M, X6 M, xDrive35i, xDrive50i and xDrive30d. Also for X5 4,8i, 3,0si, 3,0d and 3,0sd.
post #1 of 4 Old 21st July 2014, 02:45 AM Thread Starter
WallyM5
WallyM5's Avatar
For those who care, some quick steps to remove the sock from the intake.
1. Loosen hose clamp on each filter intank.
2. Pull up on the intake filter, it is secured by 3 soft rubber grommets
3. Use torx bit and remove the 4 torx bolts from the middle of the filter housing.
4. Now it swings open and you can access the carbon filters.
5. Use a flat head screw driver and press on the three tabs that hold the filter in place. Work one at a time from left to right or vice versa. They just click in place.
You're done. Enjoy
"An on ramp is a terrible thing to waste"
X5M
V1 Hardwired
Charcoal Filter Delete
K&N
Exhaust Cutouts
WallyM5 is offline
post #2 of 4 Old 5th November 2014, 01:24 PM
aspiration
aspiration's Avatar
Just curious, what's the benefit of removing this filter? Are you fitting another filter to replace it, or running filterless?
aspiration is offline
post #3 of 4 Old 5th November 2014, 03:05 PM
JohnAnthony
JohnAnthony's Avatar
it's supposed to prevent combustion fumes from escaping after you turn the car OFF, so it's just a restrictor for normal driving.
it supposed to be part of California SULEV/ULEV measures to reduce emissions
STANDARD vs SULEV
S63B44TU Charcoal Filter Delete
JohnAnthony is offline
post #4 of 4 Old 5th November 2014, 08:48 PM
aspiration
aspiration's Avatar
DIY: S63B44TU Charcoal Filter Delete ccibo72 F10 M5 Discussion 12 22nd September 2014 03:08 PM
Should I do an air filter box delete?? D-RodM5 E39 M5 and E52 Z8 Discussion 17 15th October 2010 04:25 AM
Charcoal Filter Delete LeeC3 E60 M5 and E61 M5 Touring Discussion 16 14th July 2010 08:05 PM
Charcoal Filter Delete - Warranty? David Ajax III E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 9 14th July 2010 06:40 PM
Charcoal filter delete question peterp E60 M5 and E61 M5 Touring Discussion 3 21st April 2010 12:14 AM
